Brake Booster Vacuum Leak? - Ford Truck Enthusiasts Forums
Old 02-21-2010, 01:30 AM
Dukeedee's Avatar
Dukeedee Dukeedee is offline
Dukeedee is starting off with a positive reputation.
Hey guys, I'm new so bear with me please. I have a 1992 F-250 4x4 with a 460. When I push on the brake pedal there is a hissing noise under that dash so I looked into it and where rod from the pedal goes to the booster is where it's coming from. I put my hand over the gap between the rod and the housing there and there is definitely suction there. Any ideas as to what could fix this? Could it be just a bad seal? Something relatively cheap vs a new booster? Thanks!
Old 02-21-2010, 07:05 AM
subford's Avatar
subford subford is offline
subford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud of
You need to replace the Brake Booster.
82 f150 brake booster adjustment Rusty_S 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 2 10-01-2016 11:34 AM
Brake and brake part combo questions F-250 WARHORSE 1973 - 1979 F-100 & Larger F-Series Trucks 15 08-09-2016 09:51 PM
Did I Damage My Brake Booster During Installation? jtexfisher 1994.5 - 1997 7.3L Power Stroke Diesel 7 08-01-2016 06:51 PM
need help 1960 F100 power brake booster banned 1948 - 1956 F1, F100 & Larger F-Series Trucks 21 07-26-2011 08:39 PM
Need Help -Brake Booster Problem cjf5150 1973 - 1979 F-100 & Larger F-Series Trucks 58 11-23-2006 09:20 AM
Tags
150, 2005, booster, brake, break, f150, find, ford, fordtruck, leak, noise, power, truck, vaccum, vacuum
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
