8.8 to 9.75 axle swap
It's called a Double Cardan Joint. Just on the other side of it is the slip yoke that goes into the transfer case. It's not what you'd call a two piece shaft. Wiki defines a double cardan as:
"A double cardan joint consists of two universal joints mounted back to back, with no intermediate shaft. The second UJ cancels the velocity errors introduced by the single joint, and so they act as a CV joint."
The rear tone ring may have a different number of teeth on it since it's a larger diameter. It will probably work right, but the TCM or ABS module may need adjustment for the computers to read them right (i can't remember where the wheel speed sensor data is stored on a 97). If the number of teeth are the same, then the larger ring would have bigger gaps between the teeth or bigger teeth which could also give a reading. So I am not sure how Ford compensated for this between the trucks.
The double cardan joint compensates for extreme driveshaft angles. Some years Ford used them, some they didn't. It reduces the possibility of vibration but may not necessarily be because of the short wheel base, but probably is.
yeah sure enough my drive shaft is just an inch longer, an i have the double u joint as well. but with the 2 inch block in it right now the yoke is slid out about a 1/2 inch so i may be ok with the skyjacker 5 inch rear lift springs on top of that. that will be goin in along with the rest of the lift shortly before the axle goes in an the front gears. cant wait till its all in. then time for some 37 13.50 m/t's. Then i should have a direct bolt together set up hopefully my abs sensor is the same as yours or atleast reads as it should.
