Go Back   Ford Truck Enthusiasts Forums > General > Projects
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Projects Share with other members the details about your project truck or SUV. Old or new, gas or diesel, its all welcome here!
  #1 (permalink)
Old 02-20-2010, 10:26 PM
ThaFrenchy ThaFrenchy is offline
Garage is empty, add now
ThaFrenchy is starting off with a positive reputation.
Question Step one in converting yj to ford undercarage
So il start off with the store....simple I wanted a early bronco and my old man wanted a jeep...so I ended up with a 1995 jeep yj, So after lots of swearing and bitching after the weak dana30 and dana35 axles I decided that I was gona do a axle swap. While my old man is overseas.
<?xml:namespace prefix = o ns = "urn:schemas-microsoft-comfficeffice" /><o></o>
-My first option was a set of early bronco axle with the arms and somehow retro fit the bronco dana44 front suspension setup with the arms to the jeep with the rear being the 9inch.(I gus this would be wicked setup if it work) <o></o>
<o></o>
-My second option is a set of 1968 f250 axles with closed knuckles with a matching rearend. <o></o>
<o></o>
So what’s the best? Should I use the early bronco axles or the f250 closed knuckles? Or try to find another setup….
i intend on running 38inch tires that have 15 inch rims so am looking for a setup that is able to use 15ich rims so i dont have to get rid of my tires.
let me know what you think
  #2 (permalink)
Old 02-21-2010, 07:06 PM
Customcab's Avatar
Customcab Customcab is offline
Customcab has a good reputation on FTE.Customcab has a good reputation on FTE.
Not into this type of retro; but cool to see someone doing it. Got a friend big into this type of off-roading stuff.
Looking forward to seeing your progress and project take shape.
Mitch
__________________
Mitch
63 F100 LWB 302/AOD (Orphan box) Daily Driver.
62 F100 LWB 292/3spd (Uni-body Big Window)
57 F100 SWB 351C/FMX; (Big Window)
93 F150 4x4 Regular Cab Daughters 2nd truck
62 Flairside SWB "Wife truck"
  #3 (permalink)
Old 02-21-2010, 08:10 PM
mid march am gona have acses to a heated garage to start my project, and if it gos well i might inplat a 351w in it, depending on how fast i can do the axle swap.
a fewpics of what it looks like before, as of last summer.
Click the image to open in full size.
1993 f350 side by side to the jeep
  #4 (permalink)
Old 02-22-2010, 07:26 PM
06silvercrew's Avatar
06silvercrew 06silvercrew is offline
06silvercrew has a very good reputation on FTE.06silvercrew has a very good reputation on FTE.06silvercrew has a very good reputation on FTE.
EB axles for sure! I put a set under a ranger years ago and was great. Built right the 44 will be stout.
__________________
-Scott
SOLD 2-28-11.....
'06 F250 CC/SB PSD. 2'' lift, Bilstein 5100's, Dual stabilizers, 20'' Harley wheels, 35-12.50 MT ATZ's, 08 Mirrors, ARP studs, EGR delete, 4'' MBRP, X3 with custom tunes, Full gauges, scangauge II, Coolant filter, Red top Optimas, DC 185a alt,
Tags
351w, bars, bronco, converting, early, ford, jeep, step, swap, truck, v6, yj
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
vbulletin Admin Backup
