torque tables, etc
on
torque tables, etc
putting my rear end back together and installing axles in the housing... and wondering
how much torque on the axle retainer plate "T-bolts) ??? crank them down till I can't no more... surely someone has a list of torque values to use on some of this stuff ???
anybody ???
don't say look in the shop manual...cause this 9" ain't in the '53 shop manual
tia
j
anybody ???
tia
j
Hi Jon,
Look in the shop manual, it's on page 4/28! Of course that's the 1966 Ford Shop Manual.
Might those really be called "Rear Axel Shaft Bearing Retainer Bolts?" If so the torque value is 55-65 Ft lb.
Here are the specifications pages for the 1966 rear ends (8.3/4; 9; and, 9 3/8 inch):
If you need any more info, let me know!
on
thanks Julie
I found a vague reference on a disk brake conversion article that said 55# so I was gonna start there
I also found this (never seen it before)... which gives general guidelines for bolt size... and it pretty much agrees...
General Torque Specifications:
1/4″ Grade 5 10lb/ft 1/4″ Grade 8 14lb/ft
5/16″ Grade 5 19lb/ft 5/16″ Grade 8 29lb/ft
3/8″ Grade 5 33lb/ft 3/8″ Grade 8 47lb/ft
7/16″ Grade 5 54lb/ft 7/16″ Grade 8 78lb/ft
1/2″ Grade 5 78lb/ft 1/2″ Grade 8 119lb/ft
9/16″ Grade 5 114lb/ft 9/16″ Grade 8 169lb/ft
5/8″ Grade 5 154lb/ft 5/8″ Grade 8 230lb/ft
eman92082
09-14-2017 12:02 PM
Windsor1966
05-06-2017 03:09 PM
AVR2
Escape & Escape Hybrid
04-03-2017 02:12 PM
NevetsD
1999 to 2016 Super Duty
10-04-2016 11:39 AM
wfo1955
05-25-2016 08:31 PM
