check engine light
check engine light
I think I know the answer to my own question but I want to check to make sure what you guys think. I got to take my truck out for a decent test drive today for the first time really get after it and see how it runs after my mods. It seems to pull pretty hard, hit 33 lbs of boost, but the check engine light came on. I think its probably that my 15* pump isn't big enough, am I right? Once I got home I shut her down and started it back up and the light was off.
Am I right on day to day normal towing that pump would be big enough its just that when I get after it so hard that I'm running out of oil? I pull some damn big trailers and am thinking I should just put a 17* on it or do any of you think the 15* will work? I know where I can get one pretty cheap off of a SD. That should be big enough, right? Remember I don't want a race truck, just a strong CORRECTLY put together tow rig.
Thanks guys.
Thanks guys.
I also would think the hpop. But, at 33 lbs boost you might be setting a cel that way. My 15* could not keep up eighter, it would start bucking so hard the dishes fell out of the cabinets in the 5er. I went to a 17* and problem solved. Now I have the adrenaline and love it, it never gives up.
I set a cel again just in 30 hp tow mode with an empty 5th wheel equipment trailer on. I never had it at wot at all, kinda close probably, got after it fairly good to get up to speed after turning on the highway and it set the light again. I got home, shut it off, started again and it was gone.
Think it is still just my hpop? Just checkin, don't want to be missing something I should be checking.
Thanks again guys
Thanks again guys
Sounds like the HPOP to me. Also, and I could be wrong about this, 33-lbs boost seems like a lot for these trucks. You could setting the CEL because of an overboost condition. What codes are you getting?
If you are setting an overboost code, there are ways around that, too. An inline adjustable pressure regulator set at 20 PSI, give or take, should prevent an overboost code. You'll still be boosting to 33-lbs or whatever, but the computer will only "see" what you set the regulator at.
I think a search for "Overboost Annilator" or something like that should give you plenty of information.
My od light has not been flashing at all so I shouldn't have any codes right? The only thing that has happened is the check engine light came on.
The 33 lbs of boost of course only came in the 140hp mode at wot. I wasn't over 15 lbs for sure when it set it today in the 30 hp tow mode. Actually I don't think it was over 10.
Check them anyway
OK I'll get them read. Since I didn't have money for the scan guage buy at the time I guess I'll have to find someone who can read it for me.
I started it this morning to go get fuel cause both tanks were real low. The fuel had been in there since December. That's how much I drive it in the winter. It wouldn't start in the stock mode, just try for a half a second and stop. Switched it to the tow mode and it sounded like a big cam motor when it started. It was 35* outside so not real cold. Its sitting in a shed too. It smoothed out after 15 seconds or so and wasn't smoking at all. Then I went to get fuel and it was missing on the way to the station. I left it run at the station, put fuel in it and drove a few miles and it ran fine.
Thanks guys.
Thanks guys.
Drian your fuel bowl out. I slit the edge of a 3/8" id hose and put some lube on it and using a pair of pliers pushed it up onto the end of the drain tubing and then secured it with a small worm gear. I keep it snug to the fuel lines that run on the yoke underneth the truck with tye wraps. It comes in handy if you want to see what is draining out of your bowl or if you need to drain in the garage/barn/shed or what not. Drain it into a glass and let it settle out to see if there is water in the bottom of the glass. Looking under the truck on your back, just left of center; locate the batt wire that is running to the starter. Follow it until it reaches a cable strap, reach above the cable strap to find the tubing end.
I just drained it when I did my mods at the end of january but I will do it again. I cleaned the screen in there too which wasn't bad. Just waiting for my buddy to call now so we can get the codes. He just called while on the computer here now so I guess I'll report back in a little while.
Started it to move it into the warm side of the shop and it was running real rough like a miss again while moving it over. Got in and here are the codes:
P0236 Turbo Boost Sensor A Circuit Performance --- is this an overboost code?
P0344 CMP Sensor Circuit Intermittent --- don't know need help
P0470 Exhaust Back Pressure Sensor Circuit Malfunction -- I assume this is because I eliminated my ebpv
P0603 Internal Control Module KAM Error -- don't know need help
P1211 ICP Not Controllable - Pressure Above/Below Desired -- Need help
We cleared all the codes and started it, then shut it down and checked them again. All that came up was P1111 which is system pass. It was running fine when I pulled it back around into the cold strorage part of the shop where I park it.
Any ideas and suggestions always welcome. Thanks guys
Okay
WHERE IS THE CODE FOR THIS ABOVE?
EITHER WHEN YOU CHANGED THE CPS OR IT HAS SOME WIRING ISSUES OR THE THING NEEDS A NEW ONE OR SHIMMED
P0470 Exhaust Back Pressure Sensor Circuit Malfunction -- I assume this is because I eliminated my ebpv I AGREE
THE 603 CODE IS FOR YOUR PCM KEEP ALIVE MEMORY. YOU BEEN DICONNECTING THE BATTS? IF SO IT HAS TO RUN A WHILE TO CLEAR THE CODE.
CHECK THE ICP TOP LEFT OF THE HPOP, DISCONNECT AND CHECK FOR OIL.
YOU MAY HAVE SOME BAD GPS AND YOU MAY WANT TO HOOK IT UP TO A TIMER TO RUN THE CRANK CASE HEATER ON 3 OR 4 HOURS BEFORE START UP.
<LI itxtvisited="1">P1111 System Pass (No DTCs Available) <LI itxtvisited="1">P0107 BARO Circuit Low Input <LI itxtvisited="1">P0l08 BARO Circuit High Input <LI itxtvisited="1">P0112 IAT Sensor Circuit Low Input <LI itxtvisited="1">P0113 IAT Sensor Circuit High Input <LI itxtvisited="1">P0122 Accelerator Pedal Sensor Circuit Low Input <LI itxtvisited="1">P0123 Accelerator Pedal Sensor Circuit High Input <LI itxtvisited="1">P0197 EOT Sensor Circuit Low Input <LI itxtvisited="1">P0198 EOT Sensor Circuit High Input <LI itxtvisited="1">P0220 Throttle Switch B Circuit Malfunction <LI itxtvisited="1">P0221 Throttle Switch B Circuit Performance <LI itxtvisited="1">P0230 Fuel Pump Relay Driver Fail <LI itxtvisited="1">P0231 Fuel Pump Relay Driver Circuit Failure <LI itxtvisited="1">P0232 Fuel Pump Relay Driver Failed Off <LI itxtvisited="1">P0236 Turbo Boost Sensor A Circuit Performance <LI itxtvisited="1">P0237 Turbo Boost Sensor A Circuit Low Input <LI itxtvisited="1">P0238 Turbo Boost Sensor A Circuit High Input <LI itxtvisited="1">P0261 Injector Circuit Low - Cylinder 1 <LI itxtvisited="1">P0262 Injector Circuit High - Cylinder 1 <LI itxtvisited="1">P0263 Cylinder 1 Contribution/Balance Fault <LI itxtvisited="1">P0264 Injector Circuit Low - Cylinder 2 <LI itxtvisited="1">P0265 Injector Circuit High - Cylinder 2 <LI itxtvisited="1">P0266 Cylinder 2 Contribution/Balance Fault <LI itxtvisited="1">P0267 Injector Circuit Low - Cylinder 3 <LI itxtvisited="1">P0268 Injector Circuit High - Cylinder 3 <LI itxtvisited="1">P0269 Cylinder 3 Contribution/Balance Fault <LI itxtvisited="1">P0270 Injector Circuit Low - Cylinder 4 <LI itxtvisited="1">P0271 Injector Circuit High - Cylinder 4 <LI itxtvisited="1">P0272 Cylinder 4 Contribution/Balance Fault <LI itxtvisited="1">P0273 Injector Circuit Low - Cylinder 5 <LI itxtvisited="1">P0274 Injector Circuit High - Cylinder 5 <LI itxtvisited="1">P0275 Cylinder 5 Contribution/Balance Fault <LI itxtvisited="1">P0276 Injector Circuit Low - Cylinder 6 <LI itxtvisited="1">P0277 Injector Circuit High - Cylinder 6 <LI itxtvisited="1">P0278 Cylinder 6 Contribution/Balance Fault <LI itxtvisited="1">PO279 Injector Circuit Low - Cylinder 7 <LI itxtvisited="1">P0280 Injector Circuit High - Cylinder 7 <LI itxtvisited="1">P0281 Cylinder 7 Contribution/Balance Fault <LI itxtvisited="1">P0282 Injector Circuit Low - Cylinder 8 <LI itxtvisited="1">P0283 Injector Circuit High - Cylinder 8 <LI itxtvisited="1">P0284 Cylinder 8 Contribution/Balance Fault <LI itxtvisited="1">P0301 Fault Cylinder A-Misfire? Detected (CYL 1) <LI itxtvisited="1">P0302 Fault Cylinder B-Misfire? Detected (CYL2) <LI itxtvisited="1">P0303 Fault Cylinder D-Nlisfire? Detected (CYL 3) <LI itxtvisited="1">P0304 Fault Cylinder E-Misfire? Detected (CYL 4) <LI itxtvisited="1">P0305 Fault Cylinder F-Misfire? Detected (CYL5) <LI itxtvisited="1">P0306 Fault Cylinder G-Nlisfire? Detected (CYL 6) <LI itxtvisited="1">P0307 Fault Cylinder C-Misfire? Detected (CYL 7) <LI itxtvisited="1">P0308 Fault Cylinder H-Misfire? Detected (CYL 8) <LI itxtvisited="1">P0340 CMP Sensor Circuit Malfunction <LI itxtvisited="1">P0341 CMP Sensor Circuit Performance <LI itxtvisited="1">P0344 CMP Sensor Circuit Intermittent <LI itxtvisited="1">P0360 Glow Plug Circuit Malfunction <LI itxtvisited="1">P0381 Glow Plug Indicator Circuit Malfunction <LI itxtvisited="1">P0460 Fuel <NOBR id=itxt_nobr_56_0 style="FONT-WEIGHT: normal; FONT-SIZE: 100%; COLOR: darkgreen">Tank</NOBR> Level Indicator Circuit Malfunction <LI itxtvisited="1">P0470 Exhaust Back Pressure Sensor Circuit Malfunction <LI itxtvisited="1">P0471 Exhaust Back Pressure Sensor Circuit Performance <LI itxtvisited="1">P0472 Exhaust Back Pressure Sensor Circuit Low Input <LI itxtvisited="1">P0473 Exhaust Back Pressure Sensor Circuit High Input <LI itxtvisited="1">P0476 Exhaust Pressure Control Valve Maffunction <LI itxtvisited="1">P0476 Exhaust Pressure Control Valve Performance <LI itxtvisited="1">P0478 Exhaust Pressure Control Valve High Input <LI itxtvisited="1">P0500 Vehicle Speed Sensor (VSS) Malfunction <LI itxtvisited="1">P0503 Vehicle Speed Sensor Noisy <LI itxtvisited="1">PO541 Manifold Intake Air Heater <LI itxtvisited="1">P0542 Manifold Intake Air Heater <LI itxtvisited="1">P0560 System Voltage Malfunction <LI itxtvisited="1">P0662 System Voltage Low <LI itxtvisited="1">P0563 System Voltage High <LI itxtvisited="1">P0666 Cruise 'On" Signal Malfunction <LI itxtvisited="1">P0566 Cruise "Off' Signal Malfunction <LI itxtvisited="1">P0667 Cruise 'Resume' Signal Malfunction <LI itxtvisited="1">P0668 Cruise "Set' Signal Malfunction <LI itxtvisited="1">P0669 Cruise "Coast' Signal Malfunction <LI itxtvisited="1">P0571 Brake Svdtch A Circuit Malfunction <LI itxtvisited="1">P0603 Internal Control Module KAM Error <LI itxtvisited="1">P0605 Internal Control Module ROM Error <LI itxtvisited="1">PO606 PCM Processor Fault <LI itxtvisited="1">P0640 Manifold Intake Air Heater <LI itxtvisited="1">P0670 Glow plug control circuit malfunction <LI itxtvisited="1">P0671 Glow plug #1 circuit failure <LI itxtvisited="1">P0672 Glow plug #2 circuit failure <LI itxtvisited="1">P0673 Glow plug #3 circuit failure <LI itxtvisited="1">P0674 Glow plug #4 circuit failure <LI itxtvisited="1">P0675 Glow plug #5 circuit failure <LI itxtvisited="1">P0676 Glow plug #6 circuit failure <LI itxtvisited="1">P0677 Glow plug #7 circuit failure <LI itxtvisited="1">P0678 Glow plug #8 circuit failure <LI itxtvisited="1">P0683 Glow plug diagnostic signal communication fault <LI itxtvisited="1">P0703 Brake Switch B Circuit Malfunction <LI itxtvisited="1">P0704 Clutch Pedal Position Switch Input Circuit Malfunction <LI itxtvisited="1">P0705 TR Sensor Circuit Malfunction <LI itxtvisited="1">P0707 TR Sensor Circuit Low Input <LI itxtvisited="1">P0708 TR Sensor Circuit High Input <LI itxtvisited="1">P0712 Transmission Fluid Temp. Sensor CKT Low Input <LI itxtvisited="1">P0713 Transmission Fluid Temp. Sensor CKT High Input <LI itxtvisited="1">P0715 TSS Sensor Circuit Malfunction Fault <LI itxtvisited="1">P0717 TSS Intermittent Failure <LI itxtvisited="1">P0718 Noisy TSS <LI itxtvisited="1">P0720 OSS Sensor Circuit Malfunction <LI itxtvisited="1">P0721 Noisy OSS <LI itxtvisited="1">P0722 OSS Intermittent Failure <LI itxtvisited="1">P0732 Gear Two Ratio Error <LI itxtvisited="1">P0733 Gear Three Ratio Error <LI itxtvisited="1">P0741 TCC Circuit Performance <LI itxtvisited="1">P0743 <NOBR id=itxt_nobr_107_0 style="FONT-WEIGHT: normal; FONT-SIZE: 100%; COLOR: darkgreen">Torque</NOBR> Converter Clutch System Electrical Failure <LI itxtvisited="1">P0750 Shift Solenoid 1 Malfunction <LI itxtvisited="1">P0755 Shift Solenoid B Malfunction <LI itxtvisited="1">P0781 1-2 Shift Malfunction <LI itxtvisited="1">P0782 2-3 Shift Malfunction <LI itxtvisited="1">P0783 3-4 Shift Malfunction <LI itxtvisited="1">P1000 OBD 11 Monitor Checks Not Complete. More Driving Required <LI itxtvisited="1">P1105 Dual Alternator Upper Fault (Monitor) <LI itxtvisited="1">P1106 Dual Afternator Lower Fault (Control) <LI itxtvisited="1">P1107 Dual Alternator Lower Circuit Malfunction (Control) <LI itxtvisited="1">P1108 Dual Alternator BATT Lamp Circuit Malfunction <LI itxtvisited="1">P1118 Manifold Air Temperature Sensor Low Input <LI itxtvisited="1">P1119 Manifold Air Temperature Sensor High Input <LI itxtvisited="1">P1139 Water in Fuel Indicator Circuit Malfunction <LI itxtvisited="1">P1140 Water in Fuel Condition <LI itxtvisited="1">P1184 Engine Oil Tamp Sensor Circuit Performance <LI itxtvisited="1">P1209 Injection Control System Pressure Peak Fault <LI itxtvisited="1">P1210 Injection Control Pressure Above Expected Level <LI itxtvisited="1">P1211 ICP Not Controllable - Pressure Abow/Below Desired <LI itxtvisited="1">P1212 ICP Voltage Not at Expected Level <LI itxtvisited="1">P1218 CID Stuck High <LI itxtvisited="1">P1219 CID Stuck Low <LI itxtvisited="1">P1247 Turbo Boost Pressure Low <LI itxtvisited="1">P1248 Turbo Boost Pressure Not Detected <LI itxtvisited="1">P1249 Wastagate Fail Steady State Test <LI itxtvisited="1">P1250 Electronic Passive Anti-Theft? System <LI itxtvisited="1">P1261 High to Low Side Short - Cylinder 1 <LI itxtvisited="1">P1262 High to Low Side Short - Cylinder 2 <LI itxtvisited="1">P1263 High to Low Side Short - Cylinder 3 <LI itxtvisited="1">P1264 High to Low Side Short - Cylinder 4 <LI itxtvisited="1">P1265 High to Low Side Short - Cylinder 5 <LI itxtvisited="1">P1266 High to Low Side Short - Cylinder 6 <LI itxtvisited="1">P1267 High to Low Side Short - Cylinder 7 <LI itxtvisited="1">P1268 High to Low Side Short - Cylinder 8 <LI itxtvisited="1">P1 High to Low Side Open - Cylinder 1 <LI itxtvisited="1">P2 High to Low Side Open - Cylinder 2 <LI itxtvisited="1">P3 High to Low Side Open - Cylinder 3 <LI itxtvisited="1">P4 High to Low Side Open - Cylinder 4 <LI itxtvisited="1">P5 High to Low Side Open - Cylinder 5 <LI itxtvisited="1">P6 High to Low Side Open - Cylinder 6 <LI itxtvisited="1">P7 High to Low Side Open - Cylinder 7 <LI itxtvisited="1">P8 High to Low Side Open - Cylinder 8 <LI itxtvisited="1">P1280 ICP Circuit Out of Range Low <LI itxtvisited="1">P1281 ICP Circuit Out of Range High <LI itxtvisited="1">P1282 Excessive ICP <LI itxtvisited="1">P1263 IPR Circuit Failure <LI itxtvisited="1">P1284 ICP Failure - Aborts KOER or CCT Test <LI itxtvisited="1">P1291 High Side No. 1 (Right) Short to GND or B+ <LI itxtvisited="1">P1292 High Side No. 2 (Left) Short to GND or B+ <LI itxtvisited="1">P1293 High Side Open Bank No. 1 (Right) <LI itxtvisited="1">P1294 High Side Open Bank No. 2 (Left) <LI itxtvisited="1">P1295 Multiple Faults on Bank No. 1 (Right) <LI itxtvisited="1">P1296 Multiple Faults on Bank No. 2 (Left) <LI itxtvisited="1">P1297 High Sides Shorted Together <LI itxtvisited="1">P1298 IDM Failure <LI itxtvisited="1">P1316 Injector Circuit/IDM Codes Detected <LI itxtvisited="1">P1391 Glow Plug Circuit Low Input Bank No. 1(Right) <LI itxtvisited="1">P1393 Glow Plug Circuit Low Input Bank No. 2 (Left) <LI itxtvisited="1">P1395 Glow Plug Monitor Fault Bank No. 1 <LI itxtvisited="1">P1396 Glow Plug Monitor Fault Bank No. 2 <LI itxtvisited="1">P1397 SYstem Voltage Out of Self Test Range <LI itxtvisited="1">P1464 A/C On During KOER or CCT Test <LI itxtvisited="1">P1501 VSS Out Of Self Test Range <LI itxtvisited="1">P1502 Invalid Self Test - APCM Functioning <LI itxtvisited="1">P1531 Invalid Test -Accelerator Pedal Movement <LI itxtvisited="1">P1536 <NOBR id=itxt_nobr_172_0 style="FONT-WEIGHT: normal; FONT-SIZE: 100%; COLOR: darkgreen">Parking</NOBR> Brake Applied Failure <LI itxtvisited="1">P1662 IDM EN Circuit Failure <LI itxtvisited="1">P1663 FDCS Circuit Failure <LI itxtvisited="1">P1667 CID Circuit Failure <LI itxtvisited="1">P1668 PCM -IDM Diagnostic Communication Error <LI itxtvisited="1">P1670 EF Feedback Signal Not Detected <LI itxtvisited="1">P1690 Wastegate Control Valve Malfunction <LI itxtvisited="1">P1702 TRS Sensor Intermittent Circuit Malfunction <LI itxtvisited="1">P1704 Digital TRS Failed to Transition State <LI itxtvisited="1">P1705 TR Sensor out of Self Test Range <LI itxtvisited="1">P1711 TFT Sensor Out of Self Test Range <LI itxtvisited="1">P1713 TFT Stuck in Range Low-Below? 50'F <LI itxtvisited="1">P1714 Shilt Solenoid A Inductive Signature Malfunction <LI itxtvisited="1">P1715 Shift Solenoid B Inductive Signature Malfunction <LI itxtvisited="1">P1718 TFT Stuck in Range High-Above? 25OF <LI itxtvisited="1">P1728 Transmission Slip Error <LI itxtvisited="1">P1729 4x4L Switch Error <LI itxtvisited="1">P1744 Torque Converter Clutch System Performance <LI itxtvisited="1">P1746 EPC Solenoid Open Circuit <LI itxtvisited="1">P1747 EPC Solenoid Short Circuit <LI itxtvisited="1">P1754 CCS (Solenoid) Circuit Malfunction <LI itxtvisited="1">P1760 EPC Solenoid Short Intermittent <LI itxtvisited="1">P1780 TCS Circuit Out of self Test Range <LI itxtvisited="1">P1781 4x4L Circuit Out of Self Test Range <LI itxtvisited="1">P1783 Transmission Overtemperature Condition
