2008 SD keyless entry code, RAP, computer module - Page 2 - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 11-20-2012, 09:03 AM
Iaff113's Avatar
Iaff113 Iaff113 is offline
Iaff113 is starting off with a positive reputation.
I found mine today in my 06 F350, Once I removed the storage bins as shown in pic below all I had to do was move the first white piece of fabric, then look up behind the radio. Their was another piece of fabric I pushed aside, I found the module and the code was right on the side.
Old 04-10-2013, 04:24 PM
z01tde z01tde is offline
z01tde is starting off with a positive reputation.
Found it!
Thanks genegladden for the detailed pics to find the code. I found mine after looking at your post. I just bought my used 2008 F250 and wasn't given the code. This site is very helpful for finding just about any info you may be looking for concerning your truck.
Old 01-26-2014, 12:50 AM
toolguy1964 toolguy1964 is offline
toolguy1964 is starting off with a positive reputation.
genegladden; you the man!! Exactly where it was on my truck.
Thanks!
Old 03-05-2014, 04:30 PM
tonychico11 tonychico11 is offline
tonychico11 is starting off with a positive reputation.
2008 sd keyless entry code
Your post was real usefull found the code in 10 mins thanks!!
Old 04-22-2014, 06:56 PM
gkhatta gkhatta is offline
gkhatta is starting off with a positive reputation.
Thanks, Exactly where it was on my F350 XLT
Old 07-27-2014, 03:06 PM
VictoryRider9 VictoryRider9 is offline
VictoryRider9 is starting off with a positive reputation.
THANKS!
I just want to say thanks. I bought an '09 F-250 FX4 yesterday to replace my '05 F-150 FX4 and it had no manuals or card. My wife found this thread and the '09 location for code is the same as the '08. Thanks again estan1965 and genegladden.
Old 07-27-2014, 04:32 PM
Yahiko's Avatar
Yahiko Yahiko is online now
Yahiko has a superb reputationYahiko has a superb reputationYahiko has a superb reputationYahiko has a superb reputationYahiko has a superb reputationYahiko has a superb reputationYahiko has a superb reputationYahiko has a superb reputationYahiko has a superb reputationYahiko has a superb reputationYahiko has a superb reputation
VictoryRider9,
Welcome to FTE .
Glad you found an answer to the problem.
You will find a lot of very good and useful things
here and if you look under the engine type for you
truck at the top of that forum page you will see a Tech Folder
In there you will find even more goodies to help keep
things going smooth and if you ever a problem lots of help things.
Also in this section there is a "New Member" Thread where you can introduce your self.
You can use this link or get there from the main page of this part of FTE.
http://www.ford-trucks.com/forums/78...questions.html
Sean
Old 07-30-2014, 04:24 PM
kevgrn114 kevgrn114 is offline
kevgrn114 is starting off with a positive reputation.
Hey there, new to the group.. I've had my truck since Sep of 13, had 136k miles when i bought it..
Vehicle: 2006 Ford F-350 Super Duty
Category: Not Selected
Sub-Category: Not Selected
Drive Type: RWD
Transmission Type: Transmission 5-Automatic(5R110W)
Engine Base: 6.0L - 8Cyl
Sub Model: Lariat
My truck was broken into and my radio was ripped out.. I have the dash apart now installing a new radio.. I'm also looking for the elusive code on the RAP module for the door locks. I'm pretty sure it just aint there..
I'm assuming i have to get robbed by the dealer now to pull it..
Old 07-30-2014, 04:44 PM
Yahiko's Avatar
Looks like I may be the welcome wagon.
Welcome to FTE Kevgrn114
Come on over to 6.0L Power Stroke Diesel - Ford Truck Enthusiasts Forums
You can find more about the 6.0 there and other things
Did you find the VSM? That sticker was removed around
the 2007 year I think. But you need to look on both sides
of the module.
If you know someone that has one of the better scan tools
they might be able to read the code. Also if you know someone
that has access to a Ford VCM with IDS software they can read it.
I got lucky with mine and the card was still in the owners manual
that luckily was still in the truck after 145K miles.
Sean
Old 07-30-2014, 04:49 PM
Hey there..I'll check out the 6.0 area.. no luck on the sticker but i did just get a new code reader that does more than the old one that was also stolen from the truck.. i'll see what it tells me.. no decal for me though.. I've looked all over!! :-)
Old 07-30-2014, 04:53 PM
Yahiko's Avatar
The VSM may of been replaced somewhere
along the line after the truck went into service.
Also if you get to know some of the people near you they may
be able to help. Check with your local FTE chapter.
Sean
Old 07-30-2014, 07:07 PM
HEY I FOUND IT!!!!!!
It is WAY back in there.. and the decal is facing up. The radio is already out and the dash is off. I had to remove another black box that sits behind the radio, the the VCM was behind that.. I had to reach up through the storage bin to push up on the white insulation and a conduit hose, then with the other hand stick my iPhone up in there and start taking a bunch of pics until i captured the far back corner of the decal and could just make out the numbers! :-) man what an ordeal.. If I didn't already have the dash ripped apart it would have been horrific! :-) I can now push buttons to open the door.. Hmm, sounds mundane when I put it that way..:-)
  #28
Old 01-28-2015, 12:33 PM
merricke merricke is offline
merricke is starting off with a positive reputation.
Hallelujah, I found the code (08, F250)!!
Thanks estan1965, genegladden, & Lostrider.
{any idea where the previous owner hid/lost the second key?}
  #29
Old 04-28-2015, 05:54 PM
blacklab1 blacklab1 is offline
blacklab1 is starting off with a positive reputation.
I've got the sticker stuck to my finger. I punch in the code with the doors locked, I get no response. Any other suggestions?
  #30
Old 05-10-2015, 06:35 PM
Tommy B405 Tommy B405 is offline
Tommy B405 is starting off with a positive reputation.
thank you guys estan said it was behind the passenger side kick panel and fuse bow and sure as **** there it was plain as day.also genegladden thank you also it was right where you guys said it would be .feels good to save 100 dollors,aslo for future inquires i have a 2009 F250 super duty crew cab.5.4L
how to find the keypad code article/ post jnobles06 6.0L Power Stroke Diesel 19 06-27-2016 11:08 AM
computer module location/keyless entry code REDDOG_0_0_7 1999 to 2016 Super Duty 13 10-14-2013 10:45 AM
2003 Excursion Keyless Entry... Shriner Excursion - King of SUVs 7 07-23-2006 07:58 AM
1999 F-150 Remote Keyless Entry Question pharbach 1997 - 2003 F150 12 11-23-2004 05:08 PM
Computer Module (RAP) Location?? NY-Ford-Lifer 2004 - 2008 F150 0 06-07-2004 06:33 PM
Tags
150, 2007, 2008, code, computer, computor, entry, f150, f250, f350, f550, ford, keyless, location, module, rap, system
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
