1999 Expedition Turn Signal/Hazard problem - Ford Truck Enthusiasts Forums
Expedition & Navigator 1997 - 2002 and 2003 - 2006 Ford Expedition and Lincoln Navigator
Old 02-20-2010, 02:54 PM
johnkirk johnkirk is offline
johnkirk is starting off with a positive reputation.
I have searched the forums here & can't quite find what I am looking for. The turn signals & Hazard flashers have stopped working in my 1999 Expedition. Fuses are all ok. I can't seem to locate the flasher relay. Does anyone know where it is? Does anyone have a picture of the location?
Thanks in advance for your help!
Old 02-20-2010, 03:59 PM
Ok. I found the black box that houses the blower relay & the flasher relay. Is the blue relay the flasher relay?
Thannks.
Old 02-20-2010, 04:13 PM
vze2sgxa vze2sgxa is offline
vze2sgxa is starting off with a positive reputation.
When this happend to my truck, I found it was a single burned out rear turn signal/stop bulb. Might want to check all of those first.
Old 02-20-2010, 04:41 PM
alloro alloro is offline
alloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to behold
It's under the center section of the instrument panel in the relay/flasher block.
Old 02-20-2010, 05:42 PM
1999 expedition flasher
Ok. I found the box & replaced the blue relay & nothing changed.
I did determine the following:
The brake lights don't work.
The flashers don't work.
The turn signals don't work.
However, the turn signals & brake lights both work when the flasher button on the steering column is in the on position.
Old 02-20-2010, 06:50 PM
1999 expedition turn signal blinker
Is it ok to drive with the hazard switch in the on position so that the brake lights & turn signals work?
Old 02-20-2010, 07:29 PM
In the underdash fuse box...check or replace fuses #13 (20A) and fuse #23 (10A). More than likely fuse #23 is blown.
Old 02-20-2010, 08:16 PM
Fuse 13 & 23 are both OK. I also checked all of my tail light bulbs & they are all ok. Other than replacing the turn signal swith on the steering column, I dont know what else to do.
Old 02-20-2010, 11:28 PM
Since both fuses are okay, you either mistakenly did not replace the flasher unit or the turn signal switch is no good.
Old 02-21-2010, 01:57 AM
I did replace the blue flasher. I verified that the part number on the blue unit was in fact the flasher.
If my turn signal switch is bad, why do the turn signals & brake lights work when the hazard button is in the on position, but they don't work when it is in the off position? And the hazards wont flash at all.
Thanks again for your help!
Old 02-21-2010, 08:23 AM
fordtech08's Avatar
fordtech08 fordtech08 is offline
fordtech08 is gaining momentum as a positive member of FTE.
the hazard buttun is part of the turn signal switch, when they go bad they do stupid stuff
Old 02-22-2010, 10:53 PM
Gevans17 Gevans17 is offline
Gevans17 is gaining momentum as a positive member of FTE.
turn signal switch
multifunction switch/turn signal is prone to failure on early Expeditions
Old 02-23-2010, 08:38 AM
c_hohensee c_hohensee is offline
c_hohensee is starting off with a positive reputation.
I have changed my multi-function switch twice, it was doing different strange things both times. Good thing it is easy to change.
Old 02-23-2010, 10:30 AM
Quote:
Do I need to remove the ignition key cylinder in order to remove the cowling that covers the steering wheel column? Thanks for everyone's help with this!
Old 02-23-2010, 10:01 PM
Multifunction switch R and R
Yes, the lock cylinder has to come out. Insert key and turn to RUN position; then insert punch thru hole in the lower steering column shroud and push the ignition switch lock cylinder release tab while pulling out the ignition switch lock cylinder.Twist the tilt wheel handle and shank and remove.Move gear selector to lowest position to access steering column opening cover.Release the four clips and remove the steering column opening cover.
Remove the upper and lower steering column shrouds. Remove the lower steering column shroud. Remove the upper steering column shroud.
Remove the multi function switch. Remove the two screws. Disconnect the electrical connectors. Remove the multi function switch.Then try to remember how you took it all apart!
F53 brake light and hazard flashers failure meporsche 1999 to 2016 Super Duty 5 04-03-2016 05:05 PM
Directional flasher location? Rusty Ford 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 3 11-12-2015 11:32 PM
Hazard Flasher location on 1980 F-100 Bullnose Bob 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 12 02-09-2015 09:52 PM
2001 Sportrac -Turn Signal Flasher location? hortusthird Explorer, Sport Trac, Mountaineer & Aviator 5 03-13-2006 06:04 PM
4 way flasher location silverbullet99 1978 - 1996 Big Bronco 5 01-13-2004 06:12 PM
Tags
1999, 2003, epedition, expedition, f250, flasher, ford, fuses, lights, location, relay, replacement, signal, turning, work
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
