1997-2006 Expedition & Navigator 1997 - 2002 and 2003 - 2006 Ford Expedition and Lincoln Navigator Discussion
1999 Expedition Turn Signal/Hazard problem
Old 02-20-2010, 01:54 PM
johnkirk's Avatar
johnkirk
johnkirk is offline
I have searched the forums here & can't quite find what I am looking for. The turn signals & Hazard flashers have stopped working in my 1999 Expedition. Fuses are all ok. I can't seem to locate the flasher relay. Does anyone know where it is? Does anyone have a picture of the location?
Thanks in advance for your help!
Old 02-20-2010, 02:59 PM
johnkirk's Avatar
johnkirk
johnkirk is offline
Ok. I found the black box that houses the blower relay & the flasher relay. Is the blue relay the flasher relay?
Thannks.
Old 02-20-2010, 03:13 PM
vze2sgxa's Avatar
vze2sgxa
vze2sgxa is offline
When this happend to my truck, I found it was a single burned out rear turn signal/stop bulb. Might want to check all of those first.
Old 02-20-2010, 03:41 PM
alloro's Avatar
alloro
alloro is online now
Received 4,183 Likes on 2,425 Posts
It's under the center section of the instrument panel in the relay/flasher block.
Old 02-20-2010, 04:42 PM
johnkirk's Avatar
johnkirk
johnkirk is offline
1999 expedition flasher
Ok. I found the box & replaced the blue relay & nothing changed.
I did determine the following:
The brake lights don't work.
The flashers don't work.
The turn signals don't work.
However, the turn signals & brake lights both work when the flasher button on the steering column is in the on position.
Old 02-20-2010, 05:50 PM
johnkirk's Avatar
johnkirk
johnkirk is offline
1999 expedition turn signal blinker
Is it ok to drive with the hazard switch in the on position so that the brake lights & turn signals work?
Old 02-20-2010, 06:29 PM
alloro's Avatar
alloro
In the underdash fuse box...check or replace fuses #13 (20A) and fuse #23 (10A). More than likely fuse #23 is blown.
Old 02-20-2010, 07:16 PM
johnkirk's Avatar
johnkirk
johnkirk is offline
Fuse 13 & 23 are both OK. I also checked all of my tail light bulbs & they are all ok. Other than replacing the turn signal swith on the steering column, I dont know what else to do.
Old 02-20-2010, 10:28 PM
alloro's Avatar
alloro
Since both fuses are okay, you either mistakenly did not replace the flasher unit or the turn signal switch is no good.
Old 02-21-2010, 12:57 AM
johnkirk's Avatar
johnkirk
johnkirk is offline
I did replace the blue flasher. I verified that the part number on the blue unit was in fact the flasher.
If my turn signal switch is bad, why do the turn signals & brake lights work when the hazard button is in the on position, but they don't work when it is in the off position? And the hazards wont flash at all.
Thanks again for your help!
Old 02-21-2010, 07:23 AM
fordtech08's Avatar
fordtech08
fordtech08 is offline
the hazard buttun is part of the turn signal switch, when they go bad they do stupid stuff
Old 02-22-2010, 09:53 PM
Gevans17's Avatar
Gevans17
Gevans17 is offline
turn signal switch
multifunction switch/turn signal is prone to failure on early Expeditions
Old 02-23-2010, 07:38 AM
c_hohensee's Avatar
c_hohensee
c_hohensee is offline
I have changed my multi-function switch twice, it was doing different strange things both times. Good thing it is easy to change.
Old 02-23-2010, 09:30 AM
johnkirk's Avatar
johnkirk
johnkirk is offline
Do I need to remove the ignition key cylinder in order to remove the cowling that covers the steering wheel column? Thanks for everyone's help with this!
Old 02-23-2010, 09:01 PM
Gevans17's Avatar
Gevans17
Gevans17 is offline
Multifunction switch R and R
Yes, the lock cylinder has to come out. Insert key and turn to RUN position; then insert punch thru hole in the lower steering column shroud and push the ignition switch lock cylinder release tab while pulling out the ignition switch lock cylinder.Twist the tilt wheel handle and shank and remove.Move gear selector to lowest position to access steering column opening cover.Release the four clips and remove the steering column opening cover.
Remove the upper and lower steering column shrouds. Remove the lower steering column shroud. Remove the upper steering column shroud.
Remove the multi function switch. Remove the two screws. Disconnect the electrical connectors. Remove the multi function switch.Then try to remember how you took it all apart!
Quick Reply: 1999 Expedition Turn Signal/Hazard problem
