distributor - Ford Truck Enthusiasts Forums
distributor
Old 02-20-2010, 07:30 AM
rob8210 rob8210 is offline
rob8210 is starting off with a positive reputation.
distributor
Hey guys . I was wondering , I have a 1979 f250 4x4 with a 351m, it has the small distributor cap, and any I have seen have the small cap as well, yet when I go into a parts store such as Napa , their books say it should have the big cap. You guys with 'm' motors which distributor cap does yours have and what year is it? Thanks
Old 02-20-2010, 08:01 AM
NumberDummy's Avatar
NumberDummy NumberDummy is online now
Ford Parts Specialist
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
Quote:
Someone changed the distributor, using one from a 1976 or earlier car/truck.
The same V8 distributor cap is used on all 1977/79 Passenger Cars, F100/350's, Bronco's & Econolines, regardless of what size the engine is > >
E2ZZ12106A .. Distributor Cap (Motorcraft DH411). This cap is grey.
E2ZZ12A217A .. Base Adapter (Motorcraft DJ6) / Use w/E2ZZ12106A Dist Cap.
D5AZ12106A .. Distributor Cap (Motorcraft DH354). This cap is blue.
Fits: All 1975/76 V8's.
B7A12106A .. Distributor Cap (Motorcraft DH6). This cap is black.
Fits: All 1957/74 V8's.
D5AZ12106A can be used in place of B7A12106A and vice versa.
D5AZ12106A replaced B7AZ12106A, which was the (brown) HiPo dist. cap used from 1957 thru 1973.
Old 02-20-2010, 08:23 AM
Thanks Bill. I always enjoy reading your posts, you have way too much valuable info. Is there a parts catalogue on disk that you would recommend? Unfortunately for me the local dealers all threw out their catalogues before 1980 and I've been lucky enough to have meet 1 older parts guy who has a lot of the older stuff in his memory.
Old 02-20-2010, 09:52 AM
The 1973/79 Ford Light Truck Parts Catalog is available on a CD from hipoparts.com.
If you have a Bronco: The 1973/79 Ford Passenger Car Parts Catalog is available on a CD from hipoparts.com.
Believe it...or not...Bronco parts are listed in the Ford Passenger Car Parts Catalogs from 1966 thru 1979.
Old 02-20-2010, 11:12 AM
spudgunman's Avatar
spudgunman spudgunman is offline
spudgunman is starting off with a positive reputation.
D5AZ12106A .. Distributor Cap (Motorcraft DH354). This cap is blue..
so is the D5AZ12106A a cap and adapter?
I never understood this cap and adapter thing, always seems like there is more play in the unit that way why isn't it 1 unit?
Old 02-20-2010, 05:13 PM
Quote:
Nope.
The adapter (E2ZZ12A217A) was first used in 1977. Prior years do not have it.
The dizzy used beginning in 1977 isn't the same as prior years, either.
Old 02-20-2010, 11:28 PM
spudgunman's Avatar
but why? why not 1 part? I dont understand it seems more prone to problems
DUI Distributor, 4.9 I6 KsCop 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 39 12-30-2013 06:12 PM
Distributor Question carlyoung 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 6 05-19-2012 01:56 PM
msd distributor jwtimme FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428) 7 01-04-2007 09:54 AM
Distributor Cap mtolin 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 27 01-17-2002 09:11 PM
93 F150 4x4 4.9L I6 and Distributor Cap GregCS 1987 - 1996 F150 & Larger F-Series Trucks 3 07-05-2000 10:52 PM
Tags
1957, 351m, adapter, cap, d5az12106a, dh354, dh6, distributor, dj6, e2zz12a217a, ford, motorcraft, number, part, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
