d0ve heads vs d3ve heads - Ford Truck Enthusiasts Forums
Old 02-19-2010, 09:38 PM
Home made SVT Home made SVT is offline
Home made SVT is starting off with a positive reputation.
whats the difference between d0ve and d3ve heads?
Old 02-19-2010, 11:49 PM
Hickfied Hickfied is offline
Hickfied is starting off with a positive reputation.
Emissions and horsepower.
Old 02-19-2010, 11:52 PM
85e150six4mtod 85e150six4mtod is offline
85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation
CC size, rocker design perhaps. Do you have the full number? Check it against this. No guarantee on this info, but it's a sticky at the top of the SBF forums.
Kelly hotrod - Ford Engines Page 3
Old 02-21-2010, 01:28 AM
is there any difference in port size between these heads or any other 460 heads?
Old 02-22-2010, 04:55 PM
mcdonaldm mcdonaldm is offline
mcdonaldm is gaining momentum as a positive member of FTE.
the two biggset differences between the DoVe head and D3VE head is as follows
- DOVE heads (and the C8 and C9 head) had 77 cc chambers. the D3VE head has 95cc chambers. basically the same shape, just that the D3 are deeper.
- DOVE heads have screw in rocker studs c/w rail style rocker arms non-adjustable. the D3VE head has bolt down rocker arms pedastal style non adjustable
the valves are the same size (2.08" intake, 1.65" exhaust) and for all intent and purpose the ports are the same (slight difference due to larger chamber of D3 heads) the valve lenghts are different between the two.
the DOOE heads (the Cj/scj heads) had huge valves (2.25"/1.76") and intake and exhaust ports. way too large for a street engine unless max rpm is your goal. the D2OE police interceptor engines had 2.19 intakes and ports sized inbetween the cj heads and the D0/D3 heads. probably the best all around street heads if you can find them. the D2VE heads are good boat anchors so won't even mention them.
the main hp gain from changing the D3 heads to the early heads is in the compression bump. the ports basically flow the same.
rgds
Mike
Old 02-23-2010, 07:27 PM
mark a.'s Avatar
mark a. mark a. is offline
mark a. has a great reputation on FTE.mark a. has a great reputation on FTE.mark a. has a great reputation on FTE.mark a. has a great reputation on FTE.
Do DOVE heads have the smog bump in the ex. port ? I'ts been a while since I've seen one.
Old 02-23-2010, 08:18 PM
kjett's Avatar
kjett kjett is offline
kjett is a splendid one to beholdkjett is a splendid one to beholdkjett is a splendid one to beholdkjett is a splendid one to beholdkjett is a splendid one to beholdkjett is a splendid one to beholdkjett is a splendid one to behold
Yes they do. the later D0VE's also have the thermactor hole drilled in them just like the D3's do.
cylinder head question V10man Big Block V8 - 385 Series (6.1/370, 7.0/429, 7.5/460) 6 01-26-2013 11:09 PM
D2ve-aa ??? vogey Big Block V8 - 385 Series (6.1/370, 7.0/429, 7.5/460) 1 10-02-2004 04:37 PM
D0VE -vs- C8VE heads MTTod Big Block V8 - 385 Series (6.1/370, 7.0/429, 7.5/460) 15 10-27-2003 08:41 AM
Are these good heads? trinogt Big Block V8 - 385 Series (6.1/370, 7.0/429, 7.5/460) 1 05-06-2002 12:26 AM
C8VE, C9VE, D0VE, Which are the better heads? mgessner 1973 - 1979 F-100 & Larger F-Series Trucks 5 08-27-2001 04:41 AM
Tags
460, block, cc, d0ve, d2ve, d3ve, differance, dove, ford, head, heads, intake, made, size, spec, years
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
