Excursion Tank, Anybody Put One In Yet?
#31
When using the excursion rear tank I would assume that youd have to use the excursion exhaust, or the 450/550 exhaust. I was just lookign at my 450 and it looked like it was bent around the tank differently then my 350 (450/550 have the rear tank also as another swap idea)
you can use this fuel selector POLLAK 6 Port Electric Fuel Tank Selector Valve : eBay Motors (item 270495872752 end time Mar-04-10 09:20:47 PST) and then use a different selector switch to run this valve as well as your sending unit. by that i mean use more then just a tripple pole switch, use one with 9 or 12 poles ont he back, use the 6 poles to run the selector valve like normal, but then run the center pole to the gauge and then the outer two comming from each sending unit.
#32
I put one of those valves in a 61 GMC so I could run a 40 gal tank in the bed along with the 17 gal behind the seat. Worked great.
#33
Thanks Mike, you dont exaxtly have to use one out of an excursion though, just measure the room that you have with the duals and go hunting for a tank, you might want to look into some 78-79 bronco tanks, I believe the 25 gal one is 21x31x12 and the 33 gal is 21x31x15.
#34
You got it brother, i'll get you a bunch here shortly while its still nice out today and post up here, and i'll put a tape measure in some of the pics to give you a better idea.
#35
No problem Mike, you can measure to see what you've got to work with, and then look up some dimensions online. But your best for looking for something that will have a good fit is looking for vehicles that had a tank meant for mounting behind the axle. The reason I went with the excursion tank is because I got a heck of a good deal on, $100 for the tank and $50 for parts. If I had a side exit exhaust or duals I would most likely ended up going with the bronco tank.
#39
#40
#41
Jeff,where the black circle is, there is a tad more room right here than it exactly looks, but you could get a 5'' exhaust through there, it might be a good idea to trim off the bump stop for extra room, but it can be done, you most likely will have to modify that section of the exhaust, I think I may try tomorrow to put my 4'' back in tomorrow if I have time just to see what it will do. If I get that far I'll report back with a go or no go.
#42
Hey Jeff, I was going to let you know that the day before yesterday I decided to try and put my 4'' exhaust back on, and it did fit, it was tight right between the shock and the tank, but it did fit. I think if you were to get the tank an inch or two further back than what I did, you could easily get 5'' through there.
#44
#45
