Coolant leak driving me crazy 98 EB - Ford Truck Enthusiasts Forums
Old 02-19-2010, 08:00 PM
98AWD5.0 98AWD5.0 is offline
98AWD5.0 is starting off with a positive reputation.
Hi I have a 98 Eddie Bauer AWD explorer with the 5.0 engine that is driving me nuts. It seems to leak antifreeze from time to time for no reason. The strange part is it seems to be leaking from around the dual cats in front of the muffler?? I found antifreeze on the cat skid plate but see nothing above it. I hope its not a leaking head gasket but dont know what else it could be. It wont leak for weeks then it will be all over the snow about 1-2 feet behind the front wheels. It has 145k miles but I have had to change the passanger side rear plug twice in 2 years because it has become "fouled out" almost bridged at the tip. Strange part is it runs OK just seems to loose coolant once in a while Thanks for the help Jason
Old 02-19-2010, 08:34 PM
steve(ill)'s Avatar
steve(ill) steve(ill) is offline
steve(ill) has a great reputation on FTE.steve(ill) has a great reputation on FTE.steve(ill) has a great reputation on FTE.steve(ill) has a great reputation on FTE.steve(ill) has a great reputation on FTE.
i had a manifold leak on my F150 that would lkea coolant slowly and set in the VEE of the motor below the alternator. When you drove up the slope on the driveway, etc, it would flow out the rear of the VEE and puddle on the ground under the transmission area... maybe??
How about a little stop leak or gasket sealer ? I dont like the gooy oily pills or the slimy mud type stuff. I have used the old reliable aluminum flakes in the small tube for small leaks and done fine. Last year the F150 had a head gasket leak and i tried the gasket sealer with good success. You can not add it to antifreeze like the aluminum flakes. You need to drain and flush and fill with clean water to do the sealer.
Old 02-19-2010, 08:36 PM
steve(ill)'s Avatar
Old 02-19-2010, 08:52 PM
Thanks Steve That looks like something I might try. the explorer has a rear heater for the back seat but I see no coolant lines around the cats so it seems like it has to be comming from the exhaust out the engine Thanks Jason
Old 02-19-2010, 09:23 PM
eatingdead's Avatar
eatingdead eatingdead is offline
eatingdead is starting off with a positive reputation.
I would check the freeze plugs. Sounds to me to be the reason.
Old 11-04-2010, 03:26 PM
MDHokie93 MDHokie93 is offline
MDHokie93 is starting off with a positive reputation.
Did you ever resolve this problem? I am having an identical problem with my '98 Mountaineer 5.0.
Thanks,
Jim Calvert
Simple Coolant Flush For The 6.0 Texas Bob 6.0L Power Stroke Diesel 1 11-04-2016 03:29 PM
coolant issue? stak 1987 - 1996 F150 & Larger F-Series Trucks 3 07-24-2015 07:51 PM
98 mountaineer differential problems. 78fordman Explorer, Sport Trac, Mountaineer & Aviator 5 03-08-2015 09:51 AM
How To: Correct Antifreeze Analysis/Mixture 99ExpyProblems 1999 to 2016 Super Duty 1 11-09-2013 07:53 PM
awd ? 88dually Explorer, Sport Trac, Mountaineer & Aviator 10 03-12-2012 07:27 AM
Tags
2002, 40, 50, 98, antifreeze, back, coolant, driving, explorer, f150, ford, leak, leaking, motor, side, sport, trac
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
