SPECIAL CLAMP
Not I. Jose what happened to the old one?
Maybe this will help, leveraged info.
Early ’99 Y-pipe: F81Z-6K889BA
Clamp (Y-pipe to 94-97 compressor): F81Z-8287DA or M/craft Service Part #YF-2488
Coupler (Y-pipe to 94-97’s 2” intakes): F81Z-6C640FA (2-3/8” to 2” reducer)
Clamp (I/C tube to I/C or Y-pipe) 1C3Z-6K786BA (hot side, floating bridge, constant torque – spring under nut)
Clamp (I/C tube to I/C or Y-pipe) 1C3Z-6K786AA (cold side, floating bridge)
Each model year will have a different part#
Thanks you again.
I asked in the IH dealer and they have it as a part Ford, and I asked in a Ford dealer here in Mexico and you have to order and its in a way very very high priced.
I also put the number part in powershoptroke.com and I gotten no results, I dont know why. Also I did it in RIFFraff with no results.
Jose, they are called Marmon clamps.
Here's one on ebay $13.47 + S&H, not sure about Mexico though.
Motorcraft YF2488 Clamp - Hose : eBay Motors (item 260545127760 end time Feb-27-10 21:46:02 PST)
Here's place that sells different sizes:
V-Band Clamps & Sealing Flanges
As most of us, Im getting individual parts to get the whole IC setup, and now I only need that clamp or to know if I can use the original?
Thanks you again.
Thanks you again.
Check with www.partsguyed.com or give me a call, we will get you set up.
Thanks again.
PS, I also knew something new about the part numbers input.
In my records the number is right and is the same as ther are selling on eBay. Does anybody knows if the part number of the original marmon clamp is different to this one? I dont want to buy a clamp thats is the same I have now.
Jim, I received an e-mail from where I ordered the marmon clamp, asking me if I was sure that it is the correct clamp I need. that make have a doubt, Do you know if that is the clamp to replace the stock marmon or V-clamp, end will work with the early 99 Y-pipe and the flange of the turbo???. (Im preparing everything to install the IC)
I ask because I like to be sure I send the correct parts the first time.
I'm comfirming now, the spider to turbo clamp is the F81Z8287DA
Cdn4X4
10-04-2016 12:48 PM
FuzzFace2
15
05-21-2016 09:53 PM
76f350spercamprspeal
15
02-18-2008 05:14 AM
