What are some good headlights with HID conversions?
Looking to upgrade my lights to HID, but want to make sure the headlights are made for HIDS. I don't want to put HID in factory headlights and blind people cause the spread of the HID is horrible. Any ideas? Preferably smoked headlights as I like the white/black look.
I doubt they exist. HID housings should have an auto leveling feature so that you don't blind other drivers, watch the headlights closely on any car that has them stock... they move up and down to stay level as road grades change.
Just getting new factory housings and bulbs on mine made a world of difference, buffing the lens helps but not as much as new housings. I also run some big KC spot lights for when there is no traffic coming at me and for off-road. I can see out about a 1/4 mile with those badboys.
I actually bought new aftermarket headlight that look better than stock, but now I'm wanting to go with a hid type housing/headlight. Can you link me to what you purchased please?
I have a 2008 Subaru with HID's and they do NOT adjust.
There are so retro fit kits that have been tried in the past. Some were good, others were crap. I cannot remember for sure but the good kits might have been Morimoto or something like that. The search function will probably bring up a lot of results, but that is because this has been discussed many times.
It's simple to adjust the existing or any OE replacement headlight buckets. Shine lights on a wall or garage door, mark top light cutoff on wall with masking tape. Install HIDs and adjust as necessary to match light pattern to the tape.
HID bulbs rarely emit light from exactly the same point as the stock halogens, so the reflection geometry made by the headlight bucket tends to scatter. It's not a big deal. Generally a slight adjustment down is all you need.
Bigger concern is if your truck has a chip the RF from the HIDs may interfere and cause the truck to stall when the lights are turned on. This is disconcerting at 70mph on a dark road. on the chip wire can fix that.
This is correct, but what was being referred to was auto adjusting. The HID lights on my Subaru DO NOT auto adjust. I did own a 2004 Audi S4 that the HID lights did auto adjust on.
We like to think the light at the end of the tunnel, is just a 7.3 heading your way!
Good Luck!
Research (search) this forum on headlights. LED’s are the BEST. The industry is constantly upgrading, so some of these threads are older and bulbs have improved. We like the look of white on smoke black as well.
We like to think the light at the end of the tunnel, is a 7.3 heading your way!
Good Luck!
Care to market some out to the board peeps? I just got some LED bulbs ordered and will be here tom. From reading these are 05 style lenses correct? If so that means I would have to cut some of the housing, yea?
Icthus in AK
6.7L Power Stroke Diesel
32
11-03-2014 07:31 PM
