Fuel Injector Cross Reference????
Hey guys. I was went to the salvage yard and pulled some of fuel injectors that look really new... They are from a couple different trucks and have different numbers on them (E5TE-A3B and F2TE-A3A). Just wondering if there is a cross reference chart some where??? The origional injectors (F0TE-C3A) are really rusted up and figured the cleaner ones from the yard probably have less miles and will clean and rebuild them if they'll work. I only had 10 min before the yard closed so I didn't get a chance to check if the engines were 5.0's or 5.8's...
I have a 1988 5.8 4x4.
oops .. https://www.ford-trucks.com/forums/3...ml#post2393855
my 'yellow' injectors are more of an 'orange' ..
I would go with the newer (F2) part number injectors, provided they are the same flow rate (color) as your original injectors. Both 5.0 and 5.8 trucks used the same size (19 lb/hr) injectors. The newer ones have a four hole nozzle for better fuel atomization, while the older ones have a single nozzle.
RIKIL
10-15-2011 06:55 PM
velcro7279
11-10-2009 11:19 PM
murrhee
02-08-2008 09:51 AM
