1997 Camshaft Position Sensor Recall??
I've got several letters too. For both mine and the wife's truck. You can have my letters if you want them.
As mentioned, the recall is not something you want done. A bad CPS means the truck will no longer run. If that happens, get the recall done then. On the other hand, a replacement CPS is only $25 from Ford or IH, so just pick one up and throw it in the glove box in case your CPS goes bad you don't get stranded. If it does die, swap it out and drive to Ford, then put the bad one back in and have them give you a new working one. That way you still have a spare.
You can stick your VIN in here: http://www.ford.com/owner-services/c...ll-information and see if you qualify for a free CPS. On the other hand it sucks letting a stealership touch your truck. Not to mention the SPAM you'll get on your phone/email what have you.
You can stick your VIN in here: Recall Information - Ford and see if you qualify for a free CPS. On the other hand it sucks letting a stealership touch your truck. Not to mention the SPAM you'll get on your phone/email what have you.
I used the link and have 2 recalls
07S57 CAMSHAFT POSITION (CMP) SENSOR INSPECTION / REPLACEMENT
09S09 SPEED CONTROL SYSTEM MODIFICATION
Thank you for the link
I think the cruise control "off" button on the steering wheel goes bad and they replace it, I could be wrong but it was something along those lines. I had it done, took all of five minutes. I had to have it done though as I was bringing the truck north across the border with me, and having no recalls was a requirement.
Bill
Charlie Tee
1983 - 2012 Ranger & B-Series
09-14-2015 06:36 PM
loudford
1999 to 2016 Super Duty
13
11-12-2009 06:25 AM
