Go Back   Ford Truck Enthusiasts Forums > Misc. > Aftermarket Products
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Aftermarket Products SPONSORED BY:
  #1 (permalink)
Old 02-18-2010, 02:21 PM
dumpsetr1010 dumpsetr1010 is offline
Garage is empty, add now
dumpsetr1010 is starting off with a positive reputation.
Air Lift Load Controller II
I have an air lift air controller II installed in my truck. It was in there when purchased, so I am a little blind here. The right side gauge needle is moving, however it is keeping it's minimum 5psi in the shocks. The compressor isn't coming on or trying to keep pumping air in the system. Generally if loose or has a leajk this would be an indicator (from what I have read). any ideas?
  #2 (permalink)
Old 02-21-2010, 07:28 AM
ReAX's Avatar
ReAX ReAX is offline
2002 Ford F-250
ReAX is a name known to allReAX is a name known to allReAX is a name known to allReAX is a name known to allReAX is a name known to allReAX is a name known to all
When you say right side gauge, I take it as you have dual gauges. It looks like they've changed the kit some since I last played with them. But the brief synopsis is there is a sensor in the suspension that tells the compressor to fire up and level out the truck. The picture I see does show the compressor button in the gauge panel, so I would start by trying that to see if the compressor fires up, or press the purge button and see if you can dump air and start the compressor.
A leak would show the pressure as low and the compressor will always try and compensate for the loss. Since you don't think the compressor is running, I doubt a leak would leave you with 5psi. You might want to crawl under the truck, find the level switch and try pressing it in to see if it's functioning.
__________________
Too many mods to list, so click here.
Here are my tech write ups
Look, see these two tow hooks? They look like tusks. And what kind of animal has tusks?
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
