Auto. Transmission fluid change or flush? - Ford Truck Enthusiasts Forums
Escape & Escape Hybrid Ford Escape, Ford Escape Hybrid, Mercury Mariner, Mazda Tribute
Old 02-18-2010, 11:19 AM
B 3000 B 3000 is offline
B 3000 is starting off with a positive reputation.
Bought my son a 2005 Escape 4cyl, auto, 80,000 miles 1 Owner & in great shape.
They said the transmission fluid has never been changed. My question is do I replace the filter & fluid or have the garage do a flush? What are the advantages by just having the trans. fluid flushed?
Would I run into by problems changing the filter & fluid my self?
Old 02-18-2010, 12:33 PM
bmuhlbach's Avatar
bmuhlbach bmuhlbach is offline
bmuhlbach is gaining momentum as a positive member of FTE.bmuhlbach is gaining momentum as a positive member of FTE.
there is no filter in the trans that is changeable. There is a drain plug on your trans.Someone has said they pull the plug drain out like3 or 4 quarts refill drive a bit then drain and refill 2 or 3 more times to change theres .Little more work but cheap and most fluid would be new out of the 12 quarts.
Old 02-18-2010, 02:34 PM
jas88's Avatar
jas88 jas88 is online now
jas88 has a great reputation on FTE.jas88 has a great reputation on FTE.jas88 has a great reputation on FTE.jas88 has a great reputation on FTE.jas88 has a great reputation on FTE.
Yep, I have the same Escape, 2005, 4cyl, auto. I had read after I got it that the CD4E trans did not like being flushed so what I did was I went to Wal-Mart and bought 4 gallons of Dexron ATF and I just swap out a gallon whenever I change the oil. I have done it 3 times so far, one more and I am done. When you pull the drain plug it drains out almost exactly a gallon.
Old 02-18-2010, 07:41 PM
skibender skibender is offline
skibender is starting off with a positive reputation.
You'll have the Mercon fluid in your vehicle. If you do the drain and fill, don't add Mercon V as there is a combatibility issue. Supposedly, the newer speced Mercon V fluid states on the bottle that it is combatible but I haven't heard if anyone has tried it. If you do the complete flush then switch to Mercon V.
2010 F-250 Transmission Fluid Change CollinsCD 1999 to 2016 Super Duty 6 12-05-2013 06:52 AM
Trans flush or no flush Jake_f16 1999 - 2003 7.3L Power Stroke Diesel 15 12-08-2012 08:45 AM
Transmission Pan Gasket? slowmans 6.4L Power Stroke Diesel 6 08-25-2012 08:36 PM
Auto Tranny Fluid Blue and White 1973 - 1979 F-100 & Larger F-Series Trucks 9 01-01-2012 12:15 PM
Flushing transmission fluid JonArmy 6.0L Power Stroke Diesel 14 10-30-2011 10:17 PM
Tags
06, 2000, 4x4, change, escape, f150, fluid, flush, flushed, ford, mercon, transmission, truck, v6, witch
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
