95 f150 trans swap and 2x4 to 4x4 conversion - Ford Truck Enthusiasts Forums
Old 02-18-2010, 08:34 AM
jjarboe01 jjarboe01 is offline
jjarboe01 is starting off with a positive reputation.
I have a 95 F150 with the 300 4.9 motor. My big questions is can I swap a ZF manual in for the stock trans (M5R1 or M5R2 I believe). Also, what would be the benefit. This a farm truck that does get abused in pulling and towing things. Its 2x4 for now, was also considering getting a doner truck to swap out to make this 4x4, and advice on that? Amount of work is not an issue, money is my biggest issue for both of these projects.
Old 02-18-2010, 12:04 PM
tooNz213 tooNz213 is offline
tooNz213 is starting off with a positive reputation.
good luck
Old 02-18-2010, 12:13 PM
darthice's Avatar
darthice darthice is offline
darthice is starting off with a positive reputation.
swapping from 2x4 to 4x4 is bolt up as far as the front end you can get all the parts from a junkyard. There is a good writeup on it in the articles here 2x4 to 4x4 for '80 to '96 F-100/150's .: Articles the tranny and transfer case you can get from the pull a part yard also if you trust it. try to look for a manual shift transfer case those are the easiest to do the conversion with
Old 02-18-2010, 03:48 PM
jess722 jess722 is offline
jess722 is starting off with a positive reputation.
if you are going to get a 4x4 truck to strip, it would be better to rob your parts and put on it to make one good truck..
Old 02-18-2010, 03:55 PM
darthice's Avatar
jess it is acctually extremely simple to convert a 2x4 to 4x4 on these trucks because how they set up the 4wd the front axle is just bolt in and you can find a tranny and transfer case really easy
Old 02-18-2010, 06:13 PM
fordman1090 fordman1090 is offline
fordman1090 is starting off with a positive reputation.
Its an easy swap. I just did it last month. I cleaned up all the parts before putting them on my truck and it worked out really nice.
But im still looking for a ZF and a T-Case.
Old 02-18-2010, 10:06 PM
andyman91 andyman91 is offline
andyman91 is starting off with a positive reputation.
How much did the parts cost total I was thinking about it but only have a grand to work with could I use a aod tranny the one already on my truck because I just got it rebuilt. Well ordered the remanufactured one :/ what the f$$$$$$$) if it won't work
Old 02-18-2010, 10:11 PM
zxwut?'s Avatar
zxwut? zxwut? is offline
zxwut? is gaining momentum as a positive member of FTE.zxwut? is gaining momentum as a positive member of FTE.
You may want to steer clear of this plan for a while until you can save up more money. It'd suck to get deep into it and run out of funds.
Old 02-19-2010, 02:50 PM
I"m walking into this project with $500 and plan to be quite successful thanks to pull-a-part and the ability to rebuilt transmissions and not needing the truck this spring right away. I think it should be quite simple after looking at the setup on a 4x4.
Old 02-19-2010, 03:05 PM
darthice's Avatar
exactly it is bolt up the mounting points on a 2wd front end are the same as the 4wd front end. Let me know how the swap goes
Old 02-19-2010, 03:07 PM
Once I gather the parts and rebuild the "new" front diff and begin, I'll post pics and make a guide out of it so others can go down the same road should they choose.
Old 02-19-2010, 03:11 PM
darthice's Avatar
i will be doing this swap as soon as i get the money and if i can find a front end the junkyard didnt have any the last time i went
95 E4OD trans in 93 460 4x4 jbas 1987 - 1996 F150 & Larger F-Series Trucks 9 01-12-2016 09:27 PM
4x4 swap to 2wd truck 1Austin112 1987 - 1996 F150 & Larger F-Series Trucks 17 11-12-2015 11:53 AM
trans swap tnvolsfootball 1997 - 2003 F150 8 08-15-2015 08:20 AM
M50D-R2 for a 4x4 same as 4x2? joegeds 1987 - 1996 F150 & Larger F-Series Trucks 6 03-21-2015 03:29 PM
300 to 351w swap - have some questions big-ugly Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W) 4 12-30-2011 11:02 AM
Tags
2000, 2x4, 4x4, 95, 95f150, conversion, exchange, f150, ford, mt, recalls, specs, speed, transmission, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
