351 or 400 crank? - Ford Truck Enthusiasts Forums
351 or 400 crank?
Old 02-17-2010, 10:16 PM
1980 Ford F-250's Avatar
1980 Ford F-250 1980 Ford F-250 is offline
1980 Ford F-250 is starting off with a positive reputation.
351 or 400 crank?
Okay, I bought a 1980 ford f250 and the guy i bought it from said that it had a 351m in it. I went a looked at the vin number and it said that it had a 400 in it, but when i pulled the engine apart it had 351 stamped on the pistons. So we bought a 400 crank for it and built it to be a 400. Now i have a reason to believe that it was a 400 to start out with. I still have the original crank and if it is a 400 is it worth any money? Is there a way that i can find out if it is a 351 of a 400 crank?
Thanks in advance.
Old 02-17-2010, 11:09 PM
zaaac zaaac is offline
zaaac is starting off with a positive reputation.
Old 02-18-2010, 08:32 PM
mark a.'s Avatar
mark a. mark a. is offline
mark a. has a great reputation on FTE.mark a. has a great reputation on FTE.mark a. has a great reputation on FTE.mark a. has a great reputation on FTE.
If the pistons were stamped 351 on the sides why would you think it was a 400 ?
Old 02-19-2010, 01:29 AM
85e150six4mtod 85e150six4mtod is offline
85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation
If the crank is out of the engine, 3.50 vs. 4" stroke should be easy to figure.....
Old 02-20-2010, 02:00 AM
mustang81's Avatar
mustang81 mustang81 is offline
mustang81 is starting off with a positive reputation.
Mesure the distance between the center of the crank to the center of the connecting rod. 4" is a 400 and 3.5" the 351m. The 400 as a ridge of about 1 inch at the first conterweight on the front you can feel with your fingers. The 351m don't have it. Also the 400 have 5M, 5MA or 5MAB casting number on the first conterweight. My 400 crank have 5MAB.
Old 02-20-2010, 03:19 AM
Quote:
Because according to the VIN number it is a 400
Old 02-20-2010, 04:02 AM
mustang81's Avatar
Maybe you have a 400 with 351c flat top piston ? wich is good to raise your compression with stock head. stock 351m and 400 have dish piston. Can you post a picture of the top piston ?
Old 02-20-2010, 09:28 PM
I dont have the pistons anymore and i didnt take any pictures of the old ones. From what i remember, i dont think they were flat top, but i could be wrong.
Old 02-21-2010, 01:40 AM
Quote:
What if there is just a 5 on the second counter weight from the back?
Old 02-21-2010, 02:05 AM
Quote:
Did you look at the picture on the TMeyer website? That's all you need to figure out if it's a 351M or 400 crank.
Old 02-21-2010, 01:15 PM
mustang81's Avatar
Look at zaaac first post to identify your crank, perfect pics. 5 on the second conterweight from the back don't tell me anything, maybe connecting rod # 5. Are you sure your looking at the conterweight ?
Old 02-21-2010, 02:00 PM
Scolesy8's Avatar
Scolesy8 Scolesy8 is offline
Scolesy8 is starting off with a positive reputation.
personally, on a truck that was built in the 70's, i have learned from experience dont go on vin# and what was original. over 30 some years old so things are changed. my vin said it was a 400 when i bought it, but it had a 351 in it. but i ended up swappin over 2 a 400 to start out a build on. just my 2 cents though
Old 02-22-2010, 11:24 AM
Crank throw is 1/2 the stroke. Crank centerline to rod journal centerline will be 2.0" and 1.75" for the 400/351.
Old 02-22-2010, 12:03 PM
Quote:
I did. Is the 400 crank the one on the right? If it is, that is what my crank looks like.
Old 02-22-2010, 12:24 PM
It is.
351W into the 400M? SgtEnnen 335 Series- 5.8/351M, 6.6/400, 351 Cleveland 32 08-28-2013 02:32 AM
351m/400 or 460? JMyers0901 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 13 04-08-2012 01:12 PM
400 crank ID jackdaniels250 335 Series- 5.8/351M, 6.6/400, 351 Cleveland 3 10-29-2011 10:32 PM
351M to a 400 andy 1979 1973 - 1979 F-100 & Larger F-Series Trucks 18 12-07-2010 10:44 PM
400 harmonic balancer 1980 Ford F-250 335 Series- 5.8/351M, 6.6/400, 351 Cleveland 5 09-30-2010 12:56 AM
Tags
1980, 351, 400, 5mab, 66, 77, cleveland, code, crank, crankshaft, f250, find, ford, identify, m, vs
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
