92 5.0 5 speed sloppy shifting
Sloppy how? If the stick just feels loose there is a special tapered bolt that holds the stick into place. It is easy to get to. All you have to do is pull the boot back around the shifter and you will be looking straight at it.
Be careful though, I'm on my 3rd M5ODR2 since I got my rig in June. They are weak transmissions. If the last one wasn't under warranty I would of swapped to the ZF which I highly recommend compared to these crap Mazda transmissions.
I don't know where you are from but it is very hard to find any decent manual trans re-builders anymore. So if the trans is bad, you might have to go rebuilt $$$.
Bad news: As per prior posts, shifting bushings and sometimes shift forks wear on these.
Good news: Access panel in cab allows repair with trans in truck. Replace worn parts, replace plastic plugs up top, flush it out, fill it up and drive it.
Other item on this is hydraulic clutch. Slave is concentric to input shaft, so it requires r&r of the trans to repair if leaking or goes kaput.
Good luck with it.
Good luck with it.
on
Ford F150 Ranger Explorer M5R1 / M5R2 Shifter Repair : eBay Motors (item 190329417479 end time Mar-16-10 16:53:37 PDT)
You want me to come over and put them in for you as well? :-)
what gear are you having trouble with I have had my 91 F250 for 3 years now and I am used to the shift pattren it is really long compared to a car 2nd-4th and forth should be almost touching the front seat
I bought my truck and ended up putting 6K into it with brakes shocks motor mounts and exhaust these trucks are work trucks and they get the crap kicked out of then but thet still keep running but they need alot of TLC I would look for rust on the frame and body I would rahter have a blown tranny than serious rust
F-250 WARHORSE
21
01-03-2017 08:16 PM
