While up under my dash I found a trailer brake plugged in on my 97 F350 that I picked up a few months ago. If I unplug the trailer brake then the engine wont start and when I plug it in then it starts right up. Where was this connector originally plugged in before the after market trailer brake was installed? I dont have a trailer and would like to pull out the trailer brake but dont know where the original plug is...
There is nothing that it plugs into. It shouldn't be shutting off either just from unplugging the controller. It sounds like the last owner wired it wrong somewhere.
If it says UHAUL anywhere on it then that is the problem right there! Bunch of idiots!
