Air pump (and all EGR stuff) removal on 5.8....
I removed all the EGR crap (replaced with fake sensor, which works great by the way) and want to remove the air pump as well. has anyone else done this, if so- what belt # did you use? i figure this will save me lots of time rather than sitting outside of napa switching belts for an hour- thanks
well you can get the smog pump eliminator bracket from a 5.0 and bolt it in place then belt size wont matter. otherwise you can take a piece of rope/string and route it bypassing the smog pump and then measure and use that as reference at parts store. Or you can search on here, i am sure its been mentioned. remember you will have to remove the rest of the plumbing and plug the holes in the back of the heads.
Exactly my point. The computer takes information and uses the control devices to control the engine. Removing just one sensor or control device won't magically make the system work without issue. It may appear to... but I would be interested to know what long-term effects mikeberman04's setup will have on things like spark plugs, fuel economy, and valve train.
i've had the fake sensor with real o2 sensor in for about 2 years- plugs have come out clean every time, mileage roughly about the same (a few times where it was slightly better) than the old motor before rebuild and all the egr crap was on and hooked up, and valvetrain 'seems' to be alright thus far- theres never been any chatter
on
I am going to hijack here a little bit.I am putting together a 5.0 for my 96 bronco.The air pump removed,tube plugged,selenoids unplugged.Also installed gt40 intake from explorer.No throttle body yet.Do I need to install egr?Manifold is internal egr.I am going to have 2 o2 sensors on y pipe and 1 after bazani cat.Am I going to have problems?No phony evp.I read on RJM that I needed a custom chip to make this work.
on
EGR on that motor was most likely the DPFE version, so even with a functional valve on the intake the computer will set a code because there is nowhere to connect the differential pressure sensor. So the only way around this is to disable EGR function with a tuner.. unless there are EGR valves with a DPFE built-in, if so I'm not aware of it.
A little advice.. completely remove the air tubes and valves that were attached to the air pump and plug the heads with 5/8x1" coarse bolts with copper washers, this will prevent the possibility of air leaks upstream of the main O2 sensors which is a bad thing. Also remove the vacuum lines attached to the TAB and TAD solenoids but leave them electrically plugged in.
