auto transmission fluid? FMX or C6 tranny - Ford Truck Enthusiasts Forums
Old 02-16-2010, 08:44 PM
KraZeDav's Avatar
KraZeDav KraZeDav is offline
KraZeDav is starting off with a positive reputation.
How do I identify my Tranny and Type of fluid to use?
I'm confused. I have a 1975 F350 RV w/ 460.
My automatic tranny was leaking from the pan gasklet. Should be an easy fix. Drop the pan and change the gasket.
In the past I have been told to use type F in older Ford trans.
The Haynes manual I have has confused me.
I thought I had a C6 tranny. no overdrive
Haynes Manual Ch 7B "...C6 for all other V8 engines. The FMX was installed on some F350 Vehicles until 1978.
Here is why I am confused
Haynes Manual Ch 1 -Reccomended fluids -
C6 = Dexron lll or Mercon
all others type F
Old 02-16-2010, 09:10 PM
HillbillyDeluxe81 HillbillyDeluxe81 is offline
HillbillyDeluxe81 is starting off with a positive reputation.
Ok, forget the FMX, you have a C-6. Pre 77 models use Type F. 77 and later use Dex/Merc. If your transmission is an original 75, use type F. If the transmission is from a later model, or has been rebuilt using the later style frictions....use Dex/Merc.
Old 02-16-2010, 09:31 PM
KraZeDav's Avatar
Thanks, that's a relief. I bought 10 qt of Type F "Castrol" yesterday and a gasket.
I guess if I really want to know more about the FMX that was mentioned in the manual I'll start another thread . Another day.
I just found this info in an old thread.
I guess the Haynes Manual writers had a little to much to drink that day.
Quote:
Originally Posted by horsepuller View Post
Click here: Havoline Mercon V
I couldn't cut 'n paste the url from the adobe file. In case you don't have Adobe 6.0, here's what it said:
Havoline Automatic Transmission Fluid MERCON V is
designed specifically for use in Ford Motor Company
transmissions that require a MERCON V fluid. The
enhanced properties of the MERCON V specification
offer premium performance in MERCON or DEXRON-III
applications.
• Always check your owners manual to determine the
proper automatic transmission fluid for your transmission.
• Ford transmissions manufactured before 1977 and
some pre-1982 transmissions require a Type F fluid
such as Havoline ATF Type F.
• Chrysler transmissions manufactured after 1996
require either ATF+3 or ATF+43.
meets or exceeds:
• manufacturer's performance requirements
— Ford MERCON, MERCON V
— General Motors DEXRON-III
Old 02-17-2010, 07:55 PM
KraZeDav's Avatar
two part question
Quote:
Part 1
If I presume that the C6 is original then Type F is the right fluid.
If the previous owner(s) had replaced or rebuilt it and it now requires Dex/Merc fluid, What bad thing will happen if I use Type F.
Part 2
I boughta Felpro gasket at Auto Zone. It is not cork like the one I took off. Might be a good thing.
It says do not use any sealant with this gasket. Is this a good gasket or is there something better
Old 02-17-2010, 08:03 PM
fordtech08's Avatar
fordtech08 fordtech08 is offline
fordtech08 is gaining momentum as a positive member of FTE.
part 1
look at your dipstick tube does it say use type F? type f is similar to the fluid that is sold as trick shift for harder shifts so in a trans that wants mercon you'll see firmer shifts but in a trans that wants type f you might see some slipping
part 2
yeah that is a good gasket just be sure not to over tighten
Old 02-17-2010, 08:11 PM
Answer 1: Dex/Merc has a friction modifier...(it's more slippery). If you put it in a 76, it'll cause it to slip. If you put Type F in a 77, it will increase friction on the bands/clutches.....probably causing them to wear faster and/or shudder.
Answer 2: When you say sealant, are you referring to the stuff you squeeze out of a tube?? AKA RTV gasket maker?? Or, do you mean actual gasket SEALANT (the stuff in a spray can).
Old 02-17-2010, 08:17 PM
KraZeDav's Avatar
I guess I'll find out. In 2 weeks I drive this beast to Phoenix and Back
#2 either one . I just want to to put this pan back on once with no leaks.
Old 02-17-2010, 08:28 PM
Ok, if in doubt, use the Type F. It's the lesser of the 2 evils.
Don't use any RTV on the gasket. However, some spray gasket sealant is probably a good idea......unless the gasket says specifically that the gasket should be installed dry.
Old 02-17-2010, 08:31 PM
KraZeDav's Avatar
Quote:
Originally Posted by fordtech08 View Post
part 1
WOW !!!!! You are my HERO.
I must have been having a senior moment.
I know I have pulled that dipstick more than once an read it.
This RV sits alot.
Old 02-17-2010, 08:41 PM
KraZeDav's Avatar
Thanks a bunch.
It does say use dry. I was just fishing for some tips and I got what I was looking for even though the answer was on the dipstick all this time.
I should change my name to "Dipstick"
I'm a regular user of a similar website "Jeepforum.com" and both have very knowledgeable and helpful people.
Now I have another site to burn my idle time with.
Thanks again
Old 02-17-2010, 08:46 PM
fordtech08's Avatar
glad to help hope you enjoy the trip
Old 10-30-2010, 01:30 PM
KraZeDav's Avatar
Thread revival. I had a great trip. A few months after I got back the pan started leaking again. I hate leaks. It makes a mess on my driveway.
I used a torque wrench so I would not over tighten. I re-torqued the pan bolts again. It still leaks while just sitting there.
The hardest part about dropping the pan is removing and re-installing the frame cross member bolts.
any suggestions on better gaskets.
The pan just after I replaced it.
There is some minor leakage from the threads on this shift adjusting bolt I found before I changed the gasket.
and I have a small oil leak from the main rear seal on oil pan I presume, but that is also minor. It's making a mess in my drive way
P1443 padrejerry Ranger & B-Series 33 02-06-2016 09:13 PM
transmission question cr500monster 1973 - 1979 F-100 & Larger F-Series Trucks 11 05-04-2013 03:16 PM
1975 C6 Tranny pan gasket leaking KraZeDav Clutch, Transmission, Differential, Axle & Transfer Case 12 07-24-2011 05:31 PM
c6 transmission fluid Richards73 Clutch, Transmission, Differential, Axle & Transfer Case 15 01-21-2010 11:52 PM
FMX and C6 swap?? jfarmer29 1987 - 1996 F150 & Larger F-Series Trucks 1 12-22-2004 10:49 PM
Tags
1973, 1975, 1977, 351m, atf, c6, fluid, ford, leak, manual, parts, trani, transmission, truck, type
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
