belt diagram - Ford Truck Enthusiasts Forums
belt diagram
Old 02-16-2010, 08:49 PM
Fitzgerald_welding Fitzgerald_welding is offline
Fitzgerald_welding is starting off with a positive reputation.
belt diagram
i need a belt diagram for a 89 f250 351w without the smog pump.
Old 02-16-2010, 08:50 PM
skyfox10's Avatar
skyfox10 skyfox10 is offline
skyfox10 has a very good reputation on FTE.skyfox10 has a very good reputation on FTE.skyfox10 has a very good reputation on FTE.skyfox10 has a very good reputation on FTE.
I don't know when they introduced the smog pump. did this truck have one at one point or was it removed?
and does it have AC?
Old 02-16-2010, 09:07 PM
Hitokori's Avatar
Hitokori Hitokori is offline
Hitokori is gaining momentum as a positive member of FTE.
there u go ladies dont pay attention to the belt length but everything else is the same
Old 02-16-2010, 09:11 PM
skyfox10's Avatar
Quote:
I know it's there, but why can't I see it.
Nevermind, it's working now.
Old 02-16-2010, 09:14 PM
skyfox10's Avatar
actaully, I'm not convinced that's right, gonna go check my truck
Hitokori's Avatar
hmm idk i just copied what i posted in another thread uhmmmm here is the length post #2 by urs truely lol http://www.ford-trucks.com/forums/91...ml#post8324022
Old 02-16-2010, 09:25 PM
skyfox10's Avatar
This is what is on my truck. I guess it is almost the same. The tensioner is just moved.
Old 02-16-2010, 09:32 PM
skyfox10's Avatar
In Relationship to the smog pump, the movement of the tensioner is a pretty bid deal. On my red truck, the removal of the smog pump rendered the tensioner almost useless.
Old 02-16-2010, 09:36 PM
Hitokori's Avatar
put the tensioner where the idler is like the way the 87-91 models are.... u have to remember the year difference here lol... mines an 88 and my belt is ran just like the one i posted...
so i guess thats another difference between the body stiles
Old 02-16-2010, 09:40 PM
skyfox10's Avatar
That's good info to have. I was going to ask that, but since the guy in the other thread was asking for a 95, i figure that it didn't matter.
Always learning something new.
Old 11-15-2014, 10:58 AM
Jacob Stutzman Jacob Stutzman is offline
Jacob Stutzman is starting off with a positive reputation.
Exclamation
OK I have a 5.8L 351 Windsor w/o the smog and w/o the AC basically the diagram in "hitokori's" post. the bottom one with the purple belt 73". but my dilemma is that every time I put a belt on it like that i shred it within a few miles because the tensioner is so tight that i pushes the belt down on itself and its rubbing against itself until it snaps. I have no AC on this mustang or smog pump and a friend of mine was saying i need a smog pump eliminator pulley. I saw one in the in the ford motorsport svo catalog 351W engine swap accessory drive kit 1985-1993 mustang M-8511-A351. i called the number for the catalog but it says its out of order. any help here would be great. this car was left to me by my uncle who committed suicide and he knew i would be the only person who would work on it and not sell it since it is worth a little bit of money. Its a 1984 mustang capri t-top, hatchback, with a 1978 351W, and 84' 302 heads, bored our .030 and stroked @ 4.000, the crank cam and rod and main bearing were all set @ .010 which is normal and everything has been converted to Blaster 2/MSD ignition, distributor, spark, coil, etc... Ford racing valve covers with 5/32 inch rubber seals. and roller tip rocker arms. Hooker headers and H-pipe true dual exhaust @ 2" with the last 2 foot at 2.5" chrome. rear end has interchangeable gears but is currently set at 3.11 posi. with the standard 7.5 inch rear end. When I convert the rear to discs then i will convert the rear to 8.8" also, but for now a new 7.5 works fine. my main concern is the belt i really need help figuring that out. do I need a ac eliminator bracket and pulley and a smog pump eliminator bracket and pulley or can I just go with a shorter belt and run it either above or below the tensioner? I'm not sure some help or advice would be greatly appreciated here. cant drive my baby.
Old 03-15-2016, 05:19 PM
Miguel Romero Miguel Romero is offline
Miguel Romero is starting off with a positive reputation.
Short belt route isn't working well.
My Broncos 302 Efi Motor has an extra pulley and the tensor its in a different position, I tried a different rute but isn't working well. see my diagrams attached.
belt diagram zp2141 1973 - 1979 F-100 & Larger F-Series Trucks 1 05-21-2015 01:09 PM
Serpentine belt diagram btm991 6.7L Power Stroke Diesel 1 11-08-2014 07:32 PM
V belt diagram or pictures? DonJuanDiego 1968-2013 Full Size Vans 0 06-03-2014 10:08 PM
fan belt diagram beartracks 1973 - 1979 F-100 & Larger F-Series Trucks 3 08-28-2012 05:45 PM
1998 f150 serpintine belt diagram upnorthman 1997 - 2003 F150 4 11-26-2010 03:11 PM
Tags
1997, 2001, 2006, 87, 88, 97, belt, diagram, f150, f250, ford, mustang, olds, serpentine, taurus
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
