Carb Question
Old 02-16-2010, 05:42 PM
oldtruknut's Avatar
oldtruknut
oldtruknut is offline
Carb Question
I've got a rebuilt 400 out of a 77 LTD. I plan on using the engine in one of my truck projects. I've traded around and procured an edelbrock intake and i'm thinking of using the edelbrock 600cfm carb. My question is what carb came on the engine to start with? The only information I can find is a small tag that reads Motorcraft D70E-HB. Does anyone know how much it flowed?
Old 02-16-2010, 06:13 PM
zaaac's Avatar
zaaac
zaaac is offline
On the driver's side of the carb towards the front and behind the accelerator rod should be a number for the venturi size.
FORDSIX PERFORMANCE • View topic - A list of Autolite/Motorcraft 2100/2150 carb flow rates.
Old 02-16-2010, 09:07 PM
fordeverpower's Avatar
fordeverpower
fordeverpower is offline
most likely a 1.21 or 1.14 351cfm or 300 ish. 2bbl are rated at 3.0 inches of depression vs 1.5 for a 4bbl. So you can NEVER compare the cfm with out converting it.
whisler
06-29-2017 11:03 AM
dentside owner
04-28-2017 08:04 PM
whisler
07-03-2016 08:40 PM
Kadin Cook
05-08-2016 10:58 PM
cloudflare
08-23-2015 01:24 PM
Quick Reply: Carb Question
