Carb Question - Ford Truck Enthusiasts Forums
Carb Question
Old 02-16-2010, 06:42 PM
oldtruknut oldtruknut is offline
oldtruknut is starting off with a positive reputation.
Carb Question
I've got a rebuilt 400 out of a 77 LTD. I plan on using the engine in one of my truck projects. I've traded around and procured an edelbrock intake and i'm thinking of using the edelbrock 600cfm carb. My question is what carb came on the engine to start with? The only information I can find is a small tag that reads Motorcraft D70E-HB. Does anyone know how much it flowed?
Old 02-16-2010, 07:13 PM
zaaac zaaac is offline
zaaac is starting off with a positive reputation.
On the driver's side of the carb towards the front and behind the accelerator rod should be a number for the venturi size.
FORDSIX PERFORMANCE • View topic - A list of Autolite/Motorcraft 2100/2150 carb flow rates.
Old 02-16-2010, 10:07 PM
fordeverpower's Avatar
fordeverpower fordeverpower is offline
fordeverpower is starting off with a positive reputation.
most likely a 1.21 or 1.14 351cfm or 300 ish. 2bbl are rated at 3.0 inches of depression vs 1.5 for a 4bbl. So you can NEVER compare the cfm with out converting it.
300 4 barrel conversion? cloudflare 1961 - 1966 F-100 & Larger F-Series Trucks 3 08-23-2015 02:24 PM
4 barrel help Tyaz92 1978 - 1996 Big Bronco 1 06-16-2015 11:00 AM
What oem carb should I be using ?? Penn79 1973 - 1979 F-100 & Larger F-Series Trucks 3 05-31-2014 01:16 PM
A few questions about installing Edelbrock carburetor jaspirr 1973 - 1979 F-100 & Larger F-Series Trucks 4 04-18-2010 02:07 PM
4 barrel Edlebrock Performer Intake w/ EGR and 1406 Carb for 351M? lud04X 335 Series- 5.8/351M, 6.6/400, 351 Cleveland 5 07-23-2007 05:37 PM
Tags
6l, accelerator, barrel, bbl, carb, carberatorrebuildkits, d70e, d70ehb, ford, hb, intake, motocraft, motorcraft, numbers, pump, tag
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
