Replacement keys
Old 02-16-2010, 08:38 AM
TigOldBitties's Avatar
TigOldBitties
TigOldBitties is offline
Replacement keys
Curious where most of you get your replacement keys and fobs from?
I noticed my truck Key works on the ignition switch, but not on the doors or tailgate. The key goes into the key slot, tuns around in there but doesn't do anything. But it will turn the truck on. When it comes to getting inside the truck, I have to rely on my key fob.
A guy explained that the door actuators are not activated, or are missing. I'm not real knowledgeable on this but even if that were the case, I presume the key would still work on the tailgate, which it does not.
I asked my friend I bought it off of about this, and he said he bought it that way but wasn't sure.
Can I have a place make me a key based on the Vin# or Door sticker on the side?
Old 02-17-2010, 06:22 PM
thecardoc's Avatar
thecardoc
thecardoc is offline
The door actuators have to be working if you can get inside using your key fob. It sounds like the rod came off between the lock cylinder and the door latch or maybe the plastic clip holding it broke . It is a easy fix just pull the door panel off and you will probably see right away the problem .
Old 02-17-2010, 06:28 PM
thecardoc's Avatar
thecardoc
To answer you key replacement question check Ebay . Lots of good prices on keys and fobs . Buy off Ebay then take to local hardware and have cut.
Old 02-17-2010, 10:02 PM
fordtech08's Avatar
fordtech08
fordtech08 is offline
depending on the age of the truck you should be able to go to the dealership and have the parts department make you a door key from your vin, just be ready with a lot of info to prove you own the truck
jdunk54nl
2017+ Super Duty
27
02-22-2021 02:46 PM
BII Plow Truck
2017+ Super Duty
08-22-2016 09:26 AM
donjamer
General Automotive Discussion
11-01-2015 07:14 AM
PokerMunkee
1999 to 2016 Super Duty
07-14-2015 10:58 AM
IronHorsePilot
6.7L Power Stroke Diesel
23
01-05-2015 12:16 PM
Quick Reply: Replacement keys
