Replacement keys - Ford Truck Enthusiasts Forums
Replacement keys
Old 02-16-2010, 09:38 AM
TigOldBitties TigOldBitties is offline
TigOldBitties is starting off with a positive reputation.
Replacement keys
Curious where most of you get your replacement keys and fobs from?
I noticed my truck Key works on the ignition switch, but not on the doors or tailgate. The key goes into the key slot, tuns around in there but doesn't do anything. But it will turn the truck on. When it comes to getting inside the truck, I have to rely on my key fob.
A guy explained that the door actuators are not activated, or are missing. I'm not real knowledgeable on this but even if that were the case, I presume the key would still work on the tailgate, which it does not.
I asked my friend I bought it off of about this, and he said he bought it that way but wasn't sure.
Can I have a place make me a key based on the Vin# or Door sticker on the side?
Old 02-17-2010, 07:22 PM
thecardoc thecardoc is offline
thecardoc is starting off with a positive reputation.
The door actuators have to be working if you can get inside using your key fob. It sounds like the rod came off between the lock cylinder and the door latch or maybe the plastic clip holding it broke . It is a easy fix just pull the door panel off and you will probably see right away the problem .
Old 02-17-2010, 07:28 PM
To answer you key replacement question check Ebay . Lots of good prices on keys and fobs . Buy off Ebay then take to local hardware and have cut.
Old 02-17-2010, 11:02 PM
fordtech08's Avatar
fordtech08 fordtech08 is offline
fordtech08 is gaining momentum as a positive member of FTE.
depending on the age of the truck you should be able to go to the dealership and have the parts department make you a door key from your vin, just be ready with a lot of info to prove you own the truck
Key Fob for Remote Start and no push button start jdunk54nl 2017 Super Duty 9 01-15-2017 10:46 AM
Remote Start Question BII Plow Truck 2017 Super Duty 4 08-22-2016 10:26 AM
2007 Taurus Key Fob question donjamer General Automotive Discussion 3 11-01-2015 08:14 AM
New key fob question PokerMunkee 1999 to 2016 Super Duty 3 07-14-2015 11:58 AM
programming remote start fob IronHorsePilot 6.7L Power Stroke Diesel 23 01-05-2015 01:16 PM
Tags
2003, 2006, expedition, f150, ford, key, keys, make, order, replace, replacement, replacements, truck, truckkey, vin
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
