Update on door slamming issue . . . door striker bushings - Ford Truck Enthusiasts Forums
Old 02-15-2010, 08:39 PM
JoeVR5's Avatar
JoeVR5 JoeVR5 is offline
JoeVR5 is starting off with a positive reputation.
Hi everybody,
I posted a few weeks ago about how I was really struggling with having to slam my doors REALLY hard on my 1990 Ford F250, 7.3L, ext cab, 4x4.
I was not aware that there were supposed to be bushings on the striker bolts of my truck. I found some of the bushings at Auto Zone for $5 and have put them in.
However, even with these new bushings in, it seems the doors still need a little bit of adjustment.
What is the best way to adjust these doors so I am not double and triple-slamming them every time I get in the truck?
Thanks all!
Old 02-15-2010, 09:37 PM
Hitokori's Avatar
Hitokori Hitokori is offline
Hitokori is gaining momentum as a positive member of FTE.
are the pins in the door hinge letting the door sag... this will cause shutting issues and u can buy a little kit with a new nail 2 bushings and a alittle clip that will fix it for like 6 dollars or sumthing like that
Old 02-15-2010, 09:50 PM
zxwut?'s Avatar
zxwut? zxwut? is offline
zxwut? is gaining momentum as a positive member of FTE.zxwut? is gaining momentum as a positive member of FTE.
Open your door and lift up on it. Does it move up and down? If so, stroll down to NAPA, or wherever you like, and ask for some door pins.
They look like this:
Old 02-15-2010, 11:21 PM
Hitokori's Avatar
yep those are the verry things i was talking about
Old 02-15-2010, 11:32 PM
skyfox10's Avatar
skyfox10 skyfox10 is offline
skyfox10 has a very good reputation on FTE.skyfox10 has a very good reputation on FTE.skyfox10 has a very good reputation on FTE.skyfox10 has a very good reputation on FTE.
So glad I read this thread, I need those. Do these parts just wear out or does letting the door fly open play a role as well.
Old 02-15-2010, 11:37 PM
Hitokori's Avatar
ehh they wear out and letting the door fly open adds to it... it also isnt good on where the hinges mout to the door... my driverside door is starting to sag but w/e lol
Old 02-15-2010, 11:41 PM
JoeVR5's Avatar
Hey guys,
Thanks for the suggestions . . . but nope, no door sag . . .
I used to have an old Chevy Pickup that I was trying to restore and MAN did that thing have some major door sagging issues . . . I ended up selling it
Fortunately, this F250 doesn't seem to have too many bad rust problems.
I think it may be the catch mechanism that is inside the door that is making it so difficult to close . . . is that adjustable?
Old 02-16-2010, 12:39 AM
zxwut?'s Avatar
Quote:
Originally Posted by JoeVR5 View Post
Hey guys,
I think it'd adjustable but first, have you cleaned the latch mechanism well and lubed it with some good dry lube?
Old 02-16-2010, 12:42 AM
JoeVR5's Avatar
Thanks for the suggestion . . . I'll try that tomorrow sometime!
What is the best dry lube to use in this sort of application?
Old 02-16-2010, 01:05 AM
zxwut?'s Avatar
I like to use white lithium grease from an aerosol can. There really isn't anything better for a scenario where you really want the lube to stick and stay.
Old 02-16-2010, 02:56 AM
qiaodigg qiaodigg is offline
qiaodigg is starting off with a positive reputation.
__________________
auto Insurance reviews
Old 02-16-2010, 05:41 PM
little dutch little dutch is offline
little dutch is starting off with a positive reputation.
Good information. I have a door sag issue, the door visibly pops up when closed. I opened the door and lifted it and could see the pins float around.
$5 a side at Advance.
Old 02-16-2010, 05:43 PM
skyfox10's Avatar
Quote:
Hey! You Stole My Post!
Old 02-16-2010, 07:52 PM
BucksTrucks's Avatar
BucksTrucks BucksTrucks is offline
BucksTrucks is starting off with a positive reputation.
We replaced the pins bushing and strikers on my dads 86 K1500 with 350k miles on it, you would not believe that truck was that old when you easily pulled the doors shut with one finger!
Old 02-16-2010, 07:55 PM
Hitokori's Avatar
hahaha i saw that last night and it was his first one
Help-can't open either door mike41a 1987 - 1996 F150 & Larger F-Series Trucks 16 03-02-2015 11:27 PM
What is the proper way to adjust F150 door latch/striker? 92 Red F150 1987 - 1996 F150 & Larger F-Series Trucks 20 02-10-2015 01:30 PM
Door handle fix? Door alignment? Bayer-Z28 1987 - 1996 F150 & Larger F-Series Trucks 6 03-06-2014 02:54 PM
Door striker ? V10man 1973 - 1979 F-100 & Larger F-Series Trucks 8 10-02-2012 06:33 PM
I Put in New Door Striker Bushings & now the door sticks shut ... What can I do? JoeVR5 1987 - 1996 F150 & Larger F-Series Trucks 6 02-21-2010 08:18 AM
Tags
1996, adjust, bad, bushing, bushings, door, f100, f150, f250, ford, latch, stricker, striker, strikers, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
