You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
I began having problems with headgasket, exhaust gas in coolant. I tried BARS and it worked for a while. The gasket "blew" the other day, lost at least one cylinder.
I want to keep the truck so I have to replace the head gaskets. At first I did not consider doing it myself but reading this board has given me the confidence I needed. I also see the support everyone gives each other, this is great. My plan, so far, is:
Take apart top of the engine
Have the cylinder heads re surfaced and re build
replace water pump
replace timing chains and tensioners
install new Head gaskets
put everything back together
I would appreciate any advice for the forum. If someone has done this job, any instructions would be appreciated. Anything else I should be looking at? any pictures? send them to me, kevinhennelly@comcast.net
thats too bad kev... i can get you started with the manifold photo. this is as far as i had to go. take a close look at the gasket on the aluminum water manifold bolted to the bottom of the plastic intake--- bad area... take photos.
__________________
2002 SuperCrew 4 x 4 5.4 XLT -100K miles -NEW
2010 EDGE FWD - V6 ----------30,000 miles
2002 Explorer 4 x 4 4.0 XLT --- 162,000 miles
2001 SuperCrew 4 x 4 5.4 XLT -235K miles -GONE
one thing that you will need is to get a set of head bolts they are torque to yield, so they are a one time use only
most books will tell you to pull the engine granted a head job is easier with the engine out but not everybody can pull the engine, you can pull the heads in the truck, the back bolts need to come out with the head I pull the two bolts up then wrap one rubber band around the two of them to squeeze them together and up( does that make sense it's kinda hard to explain)
__________________
Dan
01 expedition 5.4
55 F100, 4.6 Dohc project
Thanks for the help. I cannot pull the engine or lift the cab, I just do not have the facility. I was told by a guy at Ford they remove the Cab in 45 minutes, in the shop.
Keep the ideas coming, I like the rubber band idea, I understand what you mean.
when I do them in the truck ( I hate pulling cabs) I will pull the radiator out also, the coolant has to be drained anyway, and it's only 4 bolts holding it in, also I will take the exhaust manifold off with the head, also when it goes back together use a dab of silicone and the joints so when the front cover goes back on a dab goes at the block and oil pan and the block and head, then the valve cover gets 2 dabs at the head and front cover seam
__________________
Dan
01 expedition 5.4
Good idea with the radiator, it will give me more room. Please explain, take the exhaust manifold off with the head. How would I do this? I thought it has to come of the head.
Also, please explain the silicone, Not sure I understand what you are saying here.
when I remove the head I leave the exhaust maniflod bolted to it, it's easier to get the two bolts at the pipe the the 8 nuts on the side of the head,
the dab of silicone goes where ever there is a seam and a gasket, so before you put the front cover back on a dab goes on both sides where the block meets the oil pan, then 2 dab on each head where the head on block come together, then when you put the valve cover back on there will be 2 dabs on both side where the front cover and the head come together, don't get to hung up on it you'll see the silicone when you take it apart
__________________
Dan
01 expedition 5.4
If I am going to have the heads re built then I need to remove the exhaust manifold correct? Are you saying to leave the exhaust manifold on and disconnect at the "flange", the 2 bolts?
I successfully completed the head gasket repair last year thanks to everyones help. The truck runs real good, 205,000 miles and going strong.
The timing cover gasket is leaking right at the "intersection of the block, head and cover. I likely did not apply black sealant properly. It leaks 4 to 6 drops per night per side after being driven, this is not a continuous leak.
Any thoughts? Should I bite the bullet and go in and replace the gasket and re instal with proper seal? Any help, step by step? Photos ect? How involved?
