4x4 won't engage
4x4 won't engage
I have a 03 f150. The light on the dash says its in 4 wheel low range but it isn't. I don't hear the ticking under the dash when I turn the shift ****. I replaced the transfer case motor last fall. The light on the dash will not go off when I shift back into 2h. Any ideas?
I had a similar problem and I think that mine is finally fixed.
First, you must find an HONEST garage with a good code scanner and it will check the electrics making sure that electronically it is shifting in and out of 4X4.
Finally I found the problem in mine. It was shift electronically and it still would not get into the 4X4 but the mechanic found a cracked solenoid that is on the R/S firewall. There a 2 solenoids here. One for engaging the 4X4 and one for disengage. He changed only the engaging one ($50) and now I can get my 4 wheel drive to work.
Good luck!
Good luck!
the switch moves two solenoids on the fire wall. they open and send vacuum donw a hose to the axle differential. there are two hoses on the center pumpkin area of the axle that work the "on- off" 4 x 4 cylinder to engage the front axle. take the hoses off and see if one has vacuum at idle when your in 2 wheel drive, and the other has vacuum when in 4 wheel drive. if you have vacuum, the cylinder is "stuck". If you have no vacuum, follow the hoses to the passenger fender well and then up to the fire wall. if hoses are o.k., probalby the solenoids are not working.
