4x4 won't engage - Ford Truck Enthusiasts Forums
4x4 won't engage
Old 02-15-2010, 05:45 PM
cjcook cjcook is offline
cjcook is starting off with a positive reputation.
4x4 won't engage
I have a 03 f150. The light on the dash says its in 4 wheel low range but it isn't. I don't hear the ticking under the dash when I turn the shift ****. I replaced the transfer case motor last fall. The light on the dash will not go off when I shift back into 2h. Any ideas?
Old 02-26-2010, 03:23 PM
ddelong ddelong is offline
ddelong is starting off with a positive reputation.
I had a similar problem and I think that mine is finally fixed.
First, you must find an HONEST garage with a good code scanner and it will check the electrics making sure that electronically it is shifting in and out of 4X4.
Finally I found the problem in mine. It was shift electronically and it still would not get into the 4X4 but the mechanic found a cracked solenoid that is on the R/S firewall. There a 2 solenoids here. One for engaging the 4X4 and one for disengage. He changed only the engaging one ($50) and now I can get my 4 wheel drive to work.
Good luck!
Old 02-26-2010, 08:54 PM
steve(ill)'s Avatar
steve(ill) steve(ill) is offline
steve(ill) has a great reputation on FTE.steve(ill) has a great reputation on FTE.steve(ill) has a great reputation on FTE.steve(ill) has a great reputation on FTE.
the switch moves two solenoids on the fire wall. they open and send vacuum donw a hose to the axle differential. there are two hoses on the center pumpkin area of the axle that work the "on- off" 4 x 4 cylinder to engage the front axle. take the hoses off and see if one has vacuum at idle when your in 2 wheel drive, and the other has vacuum when in 4 wheel drive. if you have vacuum, the cylinder is "stuck". If you have no vacuum, follow the hoses to the passenger fender well and then up to the fire wall. if hoses are o.k., probalby the solenoids are not working.
Old 02-26-2010, 09:09 PM
We have more snow here in ohio tonight. I put the truck in 4 wheel drive and it worked. I don't know whats wrong but I will check everything out. I just hope it keeps working until the weather breaks. Thanks for the info.
Old 02-26-2010, 11:52 PM
steve(ill)'s Avatar
mind is a little tempermental on going into gear. I come to a full stop, shift into 4 x 4, pop it inot neutral to let things move around, and it does fine. Without using neutral, it might work 75% of the time.
Old 02-27-2010, 07:24 AM
Mine works when it wants to. I normally shift from neutral to drive back to park then hope it engages. I think my problem is out front though not in the transfer case. I've had the truck in 4lo and the front end was not pulling.
Old 02-27-2010, 08:18 AM
cowboy1997 cowboy1997 is offline
cowboy1997 is starting off with a positive reputation.
cj, crawl underneath and spray a little penetrating oil on the actuator shaft. it sounds like the actuator on the front axle is not moving freely.
Old 02-27-2010, 10:58 AM
Quote:
Will give it a try.
Thanks
4x4 dash indicator lights don't come on shog 2004 - 2008 F150 3 03-19-2016 12:14 PM
4x4 dash light blinking very fast! sa_hobbit 1997 - 2003 F150 1 02-14-2015 05:20 PM
NO 4X4!! 99F350bigorange 1999 - 2003 7.3L Power Stroke Diesel 43 01-12-2015 05:59 PM
Need Help With ESOF Big Sky 1999 to 2016 Super Duty 52 09-23-2014 08:23 PM
4wd won't engage 4x4greenbeast Expedition & Navigator 17 05-22-2014 01:10 PM
Tags
2003, 2005, 4x4, 99, actuator, engage, engager, f150, ford, front, moter, oil, penetrating, wont, x4
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
