Replace Cigarette Lighter with Power Port? - Ford Truck Enthusiasts Forums
Excursion - King of SUVs 2000 - 2005 Ford Excursion SPONSORED BY:
Old 02-15-2010, 04:26 PM
blowhole's Avatar
blowhole blowhole is offline
blowhole is starting off with a positive reputation.
Anyone ever replaced the stupid cigarette lighter under the cup-holders with a real-life power supply instead?? Is it just a matter of popping the lighter out and popping the power supply in?
Please advise.
Old 02-15-2010, 04:29 PM
Paul T Paul T is offline
Paul T is gaining momentum as a positive member of FTE.
Yes, it is the same thing. If you want to use the lighter in the power port it will work too. Any and all cigarette lighters throughout your vehicle are power ports.
Old 02-15-2010, 04:44 PM
housedad's Avatar
housedad housedad is offline
housedad has a superb reputationhousedad has a superb reputationhousedad has a superb reputationhousedad has a superb reputationhousedad has a superb reputationhousedad has a superb reputationhousedad has a superb reputationhousedad has a superb reputationhousedad has a superb reputationhousedad has a superb reputationhousedad has a superb reputation
They are the ORIGINAL power ports. Way back when, the only access to power in a vehicle was through the cigar lighter. As more and more personal electronics came out that used cigar lighter plugs, the car manufacturers started adding dedicated "power points" to vehicles. (the rear ashtrays started to be deleted through the years as less and less people smoked, too) The Power points sometimes cannot use or operate a lighter, but are just for accepting the power plugs.
I remember that was one of the things that made the Cadillacs and Lincolns so cool back in the 70's and 80's. there was a ashtray and lighter in each door and sometimes also in the back of the front seat. If you had something that needed power, the points were everywhere. In my 1984 Town car that I bought new, there were a total of 4. most other cars only had one in the front.
Old 02-15-2010, 09:39 PM
blowhole's Avatar
So that cigarette lighter can also be used as a power outlet?? I was always afraid it might ignite the power adapter! (I know that is foolish, just a thing!!) I suppose I can just get rid of the actual lighter and then try different adapters to see which ones work. I know the power adapter for my iPhone does not work in the lighter. I will just have to test which ones do. Otherwise, I guess I could just replace it with a simple power supply.
Old 02-16-2010, 12:06 AM
Rickx Rickx is offline
Rickx is gaining momentum as a positive member of FTE.
Quote:
Originally Posted by blowhole View Post
So that cigarette lighter can also be used as a power outlet?? I was always afraid it might ignite the power adapter! (I know that is foolish, just a thing!!) I suppose I can just get rid of the actual lighter and then try different adapters to see which ones work. I know the power adapter for my iPhone does not work in the lighter. I will myjust have to test which ones do. Otherwise, I guess I could just replace it with a simple power supply.
My phone chargers work in either port in front and everywhere else in the EX.
Old 02-16-2010, 12:26 AM
EXv10 EXv10 is offline
EXv10 has a superb reputationEXv10 has a superb reputationEXv10 has a superb reputationEXv10 has a superb reputationEXv10 has a superb reputationEXv10 has a superb reputationEXv10 has a superb reputationEXv10 has a superb reputationEXv10 has a superb reputationEXv10 has a superb reputationEXv10 has a superb reputation
You can get all that stuff at the auto parts store.
Old 02-16-2010, 12:30 AM
blowhole's Avatar
Heh, I will have to check out that auto parts store!!
Old 02-17-2010, 05:22 PM
Hollywood703 Hollywood703 is offline
Hollywood703 is starting off with a positive reputation.
I have to check the fuses on my cig lighter as it wont power up my adapter but my powerpoint will curiously enough.....
Old 02-19-2010, 11:08 PM
FallstonYJ's Avatar
FallstonYJ FallstonYJ is offline
FallstonYJ is starting off with a positive reputation.
There is no difference between a "power point" and a cig lighter! Both are fuse protected, 12V power supplies.
Old 02-19-2010, 11:19 PM
sddesigns's Avatar
sddesigns sddesigns is online now
sddesigns has a superb reputationsddesigns has a superb reputationsddesigns has a superb reputationsddesigns has a superb reputationsddesigns has a superb reputationsddesigns has a superb reputationsddesigns has a superb reputationsddesigns has a superb reputationsddesigns has a superb reputationsddesigns has a superb reputationsddesigns has a superb reputation
My iPhone works fine in all the power outlets front to back!
Old 02-19-2010, 11:21 PM
USMC616 USMC616 is offline
USMC616 is starting off with a positive reputation.
I agree there is no difference between a cigarette lighter and a power port, but my GPS will only power up in the cig lighter and not the other power ports. I do use the power ports to charge my phones.
Old 02-19-2010, 11:31 PM
FallstonYJ's Avatar
Typically when there is a problem getting power to a particular device it has to do with dirt/corrosion of some sort in the outlet or a problem with the device plug. Many times you can achieve positive contact by rotating the plug in the outlet and/or pulling it out just the slightest bit at the same time.
Old 03-10-2013, 01:25 AM
DBubba DBubba is offline
DBubba is starting off with a positive reputation.
Quote:
I have that exact problem. The prior owner years ago apparently used it for smoking and the humidity and debris from the use caused the receptacle to corrode/rust and now it is intermittent when I use it. Turn and wiggle to get good connections which has led to a blown fuse twice. I tried to run down a replacement at OReilleys (not big enough, no trim ring and 2 wire vs 3). I tried at the dealer and they had the receptable without ring. Stumped at the moment...may have to salvage yard the part
D
Old 03-10-2013, 04:01 AM
Apocalypse's Avatar
Apocalypse Apocalypse is offline
Finally happy...
Apocalypse has a superb reputationApocalypse has a superb reputationApocalypse has a superb reputationApocalypse has a superb reputationApocalypse has a superb reputationApocalypse has a superb reputationApocalypse has a superb reputationApocalypse has a superb reputationApocalypse has a superb reputationApocalypse has a superb reputationApocalypse has a superb reputation
Just grab one from the junk yard
Old 03-10-2013, 01:13 PM
jh818's Avatar
jh818 jh818 is offline
jh818 has a superb reputationjh818 has a superb reputationjh818 has a superb reputationjh818 has a superb reputationjh818 has a superb reputationjh818 has a superb reputationjh818 has a superb reputationjh818 has a superb reputationjh818 has a superb reputationjh818 has a superb reputationjh818 has a superb reputation
I would get one of these and cut the cigarette plug and hard wire it to an ignition switched 12V+. This way you'll have 3 cigarette lighter ports and 2 USB power ports for your phones and tablets.
Bell Automotive Products 5 Outlet Power Station/Dash Mount | Product Details | Pep Boys
OBD2 port no power? PCaraway 6.0L Power Stroke Diesel 8 04-22-2016 12:29 AM
Cigarette lighter LeroyM63 General Automotive Discussion 1 03-05-2016 09:05 AM
2001 F150 Cigarette Lighter Removal OkLaHoMaF150 1997 - 2003 F150 5 07-22-2014 03:08 PM
Cigar lighter to power port conversion rews2 1967 - 1972 F-100 & Larger F-Series Trucks 16 06-30-2014 07:45 PM
1997 F-250 LD power outlet / cigarette lighter ten70man 1997 - 2003 F150 1 11-11-2010 01:12 AM
Tags
150, 2003, 2005, cigarette, excursion, f150, ford, fuse, lighter, lighters, port, power, replace, replacing, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
