starts run's and then dies ??
I have a 2004 6.0 It will start and run for a few minutes 10-20 sometime's it doesn't have a enough power to drive it. It then will then just stumble and then die, you have to wait a minute or so and while turning it over(long start) it will start again. NOTE: I have changed both fuel filters, You can hear the fuel pump cycle ( Is the frame mounted pump the only one or is there one in the tank also?) Need some help in a bad way. Any one ever seen or heard of this before? PS no - check eng light and no codes That is what is baffling me , besides fuel pump problem I do not know where to start. Thanks.
Even though you don't exactly have a "no start" condition, I think the troubleshooting info in this thread could help:
https://www.ford-trucks.com/forums/8...condition.html
Thanks Bismic
I have that info already copied,and tried to check all I could yesterday (Sunday) The problem is the owner is a friend and he had it towed to his driveway, and believe it or not down here in GA> it has been snowing and freezing ever day. Friend or no friend it just to rough out there checking some of this,, Anyway I went back today and removed the plate off of the fuel pump (it is where all 4lines are at--- I had done this on my own truck before and found some trash in there ) His was full of red mud or rust I mean alot !! I pulled the pump off and cleaned it up and I blew the line out going back to the fuel tank, after putting it back on it made noise but would not prime the sytem. We got a new Ford pumpand put it on and He said it has never ran as good. I guess sometimes a little looking and a lot of luck still works. Thanks again ----- PS- I told him to put it in his dads shop and drop the fuel tank and clean it out good and replace the sock on the pick up.
red94F250
11-16-2003 11:11 AM
