Truck won't go into park HELP!!!! - Ford Truck Enthusiasts Forums
Old 02-14-2010, 08:44 PM
cclc1021 cclc1021 is offline
cclc1021 is starting off with a positive reputation.
I tried to put the truck in park and it wouldn't go. All of the other gears work fine but when I put it in park it's actually in reverse. Any help would be greatly appreciated.
Old 02-14-2010, 10:03 PM
c00nhunterjoe's Avatar
c00nhunterjoe c00nhunterjoe is offline
c00nhunterjoe has a very good reputation on FTE.c00nhunterjoe has a very good reputation on FTE.c00nhunterjoe has a very good reputation on FTE.
sounds like the shifter cable is somehow out of adjustment. might be as simple as an adjustment or the bracket by the tranny is bent. never run into that problem before. you can pop the cable off the tranny lever to make sure it is a cable problem and not an internal trans problem, make sure the truck isnt running and the wheels are chocked before attempting anything though
Old 02-15-2010, 12:01 AM
joe_13894 joe_13894 is offline
joe_13894 is gaining momentum as a positive member of FTE.joe_13894 is gaining momentum as a positive member of FTE.
Does the gearshift move "normal?" One common failure is for the fasteners up top to loosen.
Check that everything is tight down on the transmission. If that's OK then I'd suspect a worn out cable. Cables wearing out are common too.
Old 02-15-2010, 06:09 AM
FARM69's Avatar
FARM69 FARM69 is offline
FARM69 is gaining momentum as a positive member of FTE.
I've had the cable ice up bad enough not allowing it to go back into park before...
Old 02-15-2010, 06:39 AM
MADVAN's Avatar
MADVAN MADVAN is offline
MADVAN has a very good reputation on FTE.MADVAN has a very good reputation on FTE.MADVAN has a very good reputation on FTE.
Turn off the ign. (motor)
Just turn on the ign far enough to unlock
the wheel but not turn on cluster lamps.
See if it will go in park.
Could be a problem in the saftey system.
(brake lamp system, lockout solen)
Bill
Old 02-15-2010, 07:31 AM
tjbeggs's Avatar
tjbeggs tjbeggs is offline
tjbeggs is a name known to alltjbeggs is a name known to alltjbeggs is a name known to alltjbeggs is a name known to alltjbeggs is a name known to alltjbeggs is a name known to all
Could also be the bracket under the dash with those torx screws are very loose! stick your head under the dash and wiggle the shifter. There is a bracket that bolts to the shifter tube and the other end has the shift cable on it. There are two torx loosen up over time. Put a ratchet on them to check them.
Old 02-15-2010, 01:20 PM
strokin'_tatsch's Avatar
strokin'_tatsch strokin'_tatsch is offline
strokin'_tatsch has much to be proud ofstrokin'_tatsch has much to be proud ofstrokin'_tatsch has much to be proud ofstrokin'_tatsch has much to be proud ofstrokin'_tatsch has much to be proud ofstrokin'_tatsch has much to be proud ofstrokin'_tatsch has much to be proud ofstrokin'_tatsch has much to be proud of
could also be the bushings in the column if your shifter is sloppy. there are 2 bushings in there IIRC
Old 06-27-2011, 12:48 PM
chvllmagill chvllmagill is offline
chvllmagill is starting off with a positive reputation.
thanks!
having the same problem...joined just for this topic...all the suggestions are helpful - thanks!
Old 06-27-2011, 02:07 PM
Copedawg's Avatar
Copedawg Copedawg is offline
Copedawg has a brilliant futureCopedawg has a brilliant futureCopedawg has a brilliant futureCopedawg has a brilliant futureCopedawg has a brilliant futureCopedawg has a brilliant futureCopedawg has a brilliant futureCopedawg has a brilliant futureCopedawg has a brilliant futureCopedawg has a brilliant futureCopedawg has a brilliant future
Old 06-27-2011, 06:38 PM
triskadek's Avatar
triskadek triskadek is offline
triskadek is starting off with a positive reputation.
I've done this with some success, though my selector wasn't as far off as yours:
1. From inside the vehicle, place the gearshift lever (7210) in the DRIVE position (C6) or the OVERDRIVE position (4R70W and E4OD). Hang a three-pound weight on the gearshift lever.
2. Raise vehicle on a hoist and position suitable safety stands under vehicle.
3. Remove the shift cable from the transmission lever ball stud.
\/\/\/\/\/\/\/\/ DELICATE STUPID POS \/\/\/\/\/\/\/\/
4. Pull down the lock tab on the shift cable body.
^^^^^^^^^ don't break it ^^^^^^^^^^^^^^^
5. Position the gearshift lever in the DRIVE position (C6) or the OVERDRIVE position (E4OD). This is three detents from the front-most lever position with the first position counting as one.
6. Connect the cable end fitting to the transmission lever ball stud.
7. Push up on the lock tab to lock the cable in the correctly adjusted position.
8. Remove safety stands and lower vehicle from hoist. Remove the three-pound weight from the gearshift lever.
9. CAUTION: Under no circumstances should the cable be adjusted in any position other than D (drive) for the C6 automatic transmission or (D) (overdrive) for the E4OD automatic transmission.
After making the adjustment, check for park engagement. Check the gearshift lever in all detent positions with the engine (6007) running to make sure correct detent/transmission actions. Readjust if necessary.
Last edited by triskadek; 06-27-2011 at 06:44 PM. Reason: Forgot to warn about the delicate clip
Old 06-27-2011, 08:33 PM
Action4478 Action4478 is offline
Action4478 has a superb reputationAction4478 has a superb reputationAction4478 has a superb reputationAction4478 has a superb reputationAction4478 has a superb reputationAction4478 has a superb reputationAction4478 has a superb reputationAction4478 has a superb reputationAction4478 has a superb reputationAction4478 has a superb reputationAction4478 has a superb reputation
Might be these are loose Name:  loose shifter bolts.JPG
F250 7.3 help!!! Daniel Henao 1999 to 2016 Super Duty 1 04-11-2016 07:49 PM
HELP!!! Truck rolls downhill on "Park" ronquillaw Excursion - King of SUVs 26 03-21-2015 02:05 PM
HELPPPPPPPPPP!!!!!!!!!!!!!!!!! TRANNY ISSUES Tractorman1215 1987 - 1996 F150 & Larger F-Series Trucks 25 07-29-2013 08:11 PM
Won't Shift Into Park dave47111 1987 - 1996 F150 & Larger F-Series Trucks 7 02-15-2011 07:48 AM
97 Expy shift problem pablocruz69 1997-2006 Expedition & Navigator 1 04-04-2007 10:08 AM
Tags
2001, 350, bad, bushings, colum, f150, f250, f350, ford, gearshift, park, shift, shifter, sloppy, transmission, truck, turbo, wont
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
