camshaft for the IDI: "The torque cam" Typ4 - Page 5 - Ford Truck Enthusiasts Forums
  #61
Old 02-04-2011, 11:15 PM
BIG BAD BENTON's Avatar
BIG BAD BENTON BIG BAD BENTON is offline
BIG BAD BENTON is starting off with a positive reputation.
how do you get one of these cams? i want one
  #62
Old 02-04-2011, 11:25 PM
Jayme Duty Jayme Duty is offline
Jayme Duty is starting off with a positive reputation.
Just my opinon, These motors do very well stock and the amount of power you can increase per dollar is not worth it.. There are simple modes that are great like the soup bowl and welding in a $10 piece of tube in place of the muffler for a straight pipe. I do love all the threads with all the custom intakes the members have created but once again just my opinon, the spending 100's of dollars for a couple hp not for me.
  #63
Old 02-05-2011, 12:42 PM
wreckinball's Avatar
wreckinball wreckinball is offline
wreckinball is gaining momentum as a positive member of FTE.
that it is bro, that it is! lol. But i can tell you, its more than a couple HP with my exhaust and intake i modified. i hear what you are saying but if no one ever changes anything, no advancements can be made.
  #64
Old 02-05-2011, 12:54 PM
oreocreaming's Avatar
oreocreaming oreocreaming is offline
oreocreaming is gaining momentum as a positive member of FTE.
Quote:
you also have to look at the long term gains as well. It brings your pak hp and torque down a fe hundred rpm's. Saves fuel and wear on the enginee. Sounds like a good option to me bud
  #65
Old 04-16-2011, 02:54 PM
Royson12's Avatar
Royson12 Royson12 is offline
Royson12 is starting off with a positive reputation.
I am assuming a cam out of a 7.3 will work for the regrind? It would get installed in my 6.9 with new rollers, rebuilding the motor right now anyway. Gonna have a banks sidewinder waste gated on it. How do i get it done?
  #66
Old 04-16-2011, 03:06 PM
fordhorse's Avatar
fordhorse fordhorse is offline
fordhorse is starting off with a positive reputation.
talk to russ on oil burners
Oilburners.net
  #67
Old 04-16-2011, 03:08 PM
type4 is his name here and there, spelled different in obe of tem but basically te same
  #68
Old 04-17-2011, 06:41 PM
hairyboxnoogle's Avatar
hairyboxnoogle hairyboxnoogle is offline
hairyboxnoogle is gaining momentum as a positive member of FTE.hairyboxnoogle is gaining momentum as a positive member of FTE.
Im curious about taller ratio rockers as well, and idea that had occured to me a lil while back. Anyone know off the top of thier heads what ratio ours are? Little head machining and i think we could put about any rocker on there.
Next, does anyone know how good our valve springs are to X rpms? Is there a stiffer spring alternative?
  #69
Old 04-17-2011, 07:11 PM
rhkcommander959's Avatar
rhkcommander959 rhkcommander959 is offline
rhkcommander959 is starting off with a positive reputation.
Quote:
Depending on their shape, stock are good up to 4k MAYBE. I've heard of others using stiffer springs but IDK where I read it, I'll go diggin
  #70
Old 04-17-2011, 07:21 PM
Hey man ya sure dont have to but thanks if ya do. Plannin the 4k governor for my 6.9.
  #71
Old 06-09-2011, 01:16 AM
Marianna2003 Marianna2003 is offline
Marianna2003 is gaining momentum as a positive member of FTE.
It sure would be sweet if an existing rocker setup could be used in the IDI. Has anyone looked into this?
  #72
Old 07-24-2011, 03:07 PM
Otahyoni's Avatar
Otahyoni Otahyoni is offline
Otahyoni has a good reputation on FTE.Otahyoni has a good reputation on FTE.
I hear the 7.3L rocker swap onto a 6.9L, but whats the real difference?
  #73
Old 07-24-2011, 03:30 PM
they are stronger or more reliable... I cant remember 100%
I have been reading from a couple guys that PSD springs should fit without modification/machine work.
  #74
Old 07-24-2011, 04:52 PM
FORDF250HDXLT's Avatar
FORDF250HDXLT FORDF250HDXLT is offline
FORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant future
Quote:
just send a pm to Russ.
the guy who replied to this thread in post #2:
http://www.ford-trucks.com/forums/93...ml#post8513377
  #75
Old 09-12-2011, 01:44 PM
sak778's Avatar
sak778 sak778 is offline
sak778 is starting off with a positive reputation.
dyno?
So has this cam been dyno'd before and after yet?
oreocreaming? Have you done this yet?
Anybody???
Updates?
YMMV
93 7.3 IDI build IDIoit Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 170 02-08-2017 10:17 PM
1979 Shortie 4x4 with 300+NV4500+241 SixPoppin' Ford Inline Six, 200, 250, 4.9L / 300 19 10-17-2016 12:35 AM
?DB2 Automatic Advance ADJUSTMENT? and I/P Timing HELP Needed in Germany Fixnstuff Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 51 06-17-2016 10:26 PM
DiMora's 400 build - part deux dimora 335 Series- 5.8/351M, 6.6/400, 351 Cleveland 175 04-04-2015 04:48 AM
Cam Question Steve_B Flathead V8 & Flathead 6 5 05-30-2004 10:36 PM
Tags
1999, 73, bigger, cam, camshaft, engine, f250, idi, international, logger, logging, profiles, stock, theory, turbocharged, type, type4, upgrade
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
