camshaft for the IDI: "The torque cam" Typ4 - Page 4 - Ford Truck Enthusiasts Forums
  #46
Old 06-09-2010, 01:16 AM
oreocreaming's Avatar
oreocreaming oreocreaming is offline
oreocreaming is gaining momentum as a positive member of FTE.
as soon as i get this engine torn down i will be sending mine out. cant wait to get this damn engine in.....
  #47
Old 06-09-2010, 02:29 AM
swooshcmk swooshcmk is offline
swooshcmk is starting off with a positive reputation.
I wish I had learned about the camshaft availability about a month sooner when I had mine apart! Ah well....
  #48
Old 06-09-2010, 08:50 AM
Festus Hagen's Avatar
Festus Hagen Festus Hagen is offline
Methanoholic
Festus Hagen has a great reputation on FTE.Festus Hagen has a great reputation on FTE.Festus Hagen has a great reputation on FTE.Festus Hagen has a great reputation on FTE.Festus Hagen has a great reputation on FTE.
Old lifters on new cam equals flat lobes!
I'll be surprised if that cam is still good, even if only ran for a few minutes, the first few minutes are EVERYTHING to a new cam!
Seen it done many many times, results were the same every time... Wiped cam!
It may still look visually ok.
-Enjoy
fh : )_~
  #49
Old 07-05-2010, 02:59 PM
ajgoldsmith ajgoldsmith is offline
ajgoldsmith is starting off with a positive reputation.
I am also looking to squeeze a few more ponies out of my IDI and would be very interested in seeing a before and after dyno with this cam.
Typ4, would I have to send in a core with my order or do you have cores and could send the reground one, we can swap and send our old one back to you for core charge?
  #50
Old 07-05-2010, 03:19 PM
wreckinball's Avatar
wreckinball wreckinball is offline
wreckinball is gaining momentum as a positive member of FTE.
i might pull the cams out of my old engine i cant get rid of and get some more power!! haha,
  #51
Old 07-07-2010, 12:44 AM
87crewdually's Avatar
87crewdually 87crewdually is offline
87crewdually has a great reputation on FTE.87crewdually has a great reputation on FTE.87crewdually has a great reputation on FTE.87crewdually has a great reputation on FTE.87crewdually has a great reputation on FTE.87crewdually has a great reputation on FTE.
-Enjoy
fh : )_~
Not on a roller motor, which IDI lifters are.
  #52
Old 07-07-2010, 01:26 AM
Methanoholic
Quote:
Point taken, still not a good idea though.
-Enjoy
fh : )_~
  #53
Old 10-24-2010, 02:53 PM
typefour's Avatar
typefour typefour is offline
typefour is starting off with a positive reputation.
So, I have a great cam supplier , he wants me to offer a cam to someone at a reduced cost but they have to do a before and after dyno comparo, same timing and injectors, maybe even 2 cams one on a turbo truck and one non.
He also said the lifters are ok to reuse if they are very smooth, and they recommended that they be taken apart and clean the varnish out so they will travel fully, that is what I did on mine.
The OB member with lifter trouble had a reman engine with non standard lifters we deduced after some discussion.
  #54
Old 10-24-2010, 03:01 PM
WarOzz's Avatar
WarOzz WarOzz is offline
WarOzz is gaining momentum as a positive member of FTE.
Sounds like a a great opportunity for someone that has the time to swap cams and do the testing! Mines a daily driver so I am out
  #55
Old 10-24-2010, 03:07 PM
how much we looking at typefour? I think i have a dyno place here in victoria narrowed down. I would be very curious to see how this would perform!
  #56
Old 10-24-2010, 04:47 PM
im interested...... as soon as im done with my gears and get it back on the road in a couple weeks id be happy to do it. ive got a core cam to send in if need be. ive got a local dyno place that says that my truck on 46's isnt a big deal either.
  #57
Old 11-06-2010, 12:24 AM
FORDF250HDXLT's Avatar
FORDF250HDXLT FORDF250HDXLT is offline
FORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant future
bumpy.bumpy.
  #58
Old 11-06-2010, 12:40 AM
indeed! I'm ready and willing!!!
  #59
Old 11-06-2010, 09:55 AM
joe f350 joe f350 is offline
joe f350 has a good reputation on FTE.joe f350 has a good reputation on FTE.joe f350 has a good reputation on FTE.
im in theree a local dyno less them a mile form my house
  #60
Old 11-06-2010, 12:27 PM
'88 E-350 '88 E-350 is offline
'88 E-350 is starting off with a positive reputation.
Have any of you looked into higher ratio rockers? That would be an easier way to increase lift & duration. I've never seen any advertised for these, but there may be one that adapts easily.
?DB2 Automatic Advance ADJUSTMENT? and I/P Timing HELP Needed in Germany Fixnstuff Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 51 06-17-2016 10:26 PM
Cam Issues -- Is this cam right? Macrobb Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 2 09-17-2014 12:18 AM
How do I set cam timing on a 223 I-6 paintrx 1961 - 1966 F-100 & Larger F-Series Trucks 8 09-19-2012 11:59 PM
All about Cams-- F-250 restorer Ford Inline Six, 200, 250, 4.9L / 300 0 10-05-2010 08:24 PM
460 Throttle response question, sputtering 86rustbucket Big Block V8 - 385 Series (6.1/370, 7.0/429, 7.5/460) 3 04-04-2007 02:42 AM
Tags
1999, 73, bigger, cam, camshaft, engine, f250, idi, international, logger, logging, profiles, stock, theory, turbocharged, type, type4, upgrade
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
