camshaft for the IDI: "The torque cam" Typ4 - Page 10 - Ford Truck Enthusiasts Forums
  #136
Old 07-20-2014, 06:36 AM
Dieselpumpuk Dieselpumpuk is offline
Dieselpumpuk is starting off with a positive reputation.
Type4
Who's doing a grind this week?
  #137
Old 01-26-2015, 05:42 PM
Still no response from R&D
Hello if anyone over there can get hold of R&D as I'm still trying to get these parts
I now have a 1993 7.3 factory turbo engine in my truck.
Cam stage1 or 2
Comp 910's
New headbolt/studs
Head gasket set
Upgraded clutch for zf5
Pump upgrade
Turbo upgrade
Injector upgrade
New glowplugs
If someone could at least give the guy a nudge as he's not responding to any of my emails?? My contact details are on www.dieselpumpuk.com or email luke.dale1@btinternet.com.
Thanks for the advice on cams everyone now I just need to get one here!!
  #138
Old 01-26-2015, 08:50 PM
Macrobb's Avatar
Macrobb Macrobb is offline
Macrobb is gaining momentum as a positive member of FTE.
Cam stage1 or 2
Comp 910's
New headbolt/studs
Head gasket set
Pump upgrade
Turbo upgrade
Injector upgrade
New glowplugs
If someone could at least give the guy a nudge as he's not responding to any of my emails?? My contact details are on Diesel Pump UK | Super Turbo Diesel Tuning Innovations or email luke.dale1@btinternet.com.
Are you talking about Russ/Typ4(i.e. who this topic is about), or Justin/R&D IDI Performance?
  #139
Old 01-27-2015, 02:37 AM
Quote:
I'm actually talking about Justin (R&D) but anyone that can supply the parts would be great!!
  #140
Old 01-27-2015, 06:10 AM
FORDF250HDXLT's Avatar
FORDF250HDXLT FORDF250HDXLT is offline
FORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant future
well at least you know your hijacking lol.
tip;
people who have trucks and parts to sell here are supposed to be using the devoted marketplace to list their stuff and provide their contact info.i would begin searching there.if you don't see them and their parts listed there,you could send them a pm letting them know,they're loosing a potential major revenue.
http://www.ford-trucks.com/forums/forum231/
  #141
Old 12-06-2015, 04:47 PM
94iditpuller's Avatar
94iditpuller 94iditpuller is offline
94iditpuller is starting off with a positive reputation.
5yrs still no numbers i thought it was low $ for dyno #
  #142
Old 12-06-2015, 05:04 PM
Ford F834's Avatar
Ford F834 Ford F834 is offline
Ford F834 has a very good reputation on FTE.Ford F834 has a very good reputation on FTE.Ford F834 has a very good reputation on FTE.
Problem is that no one has yet done a before and after dyno run where the only change is the cam. There are lots of dyno results but no comparisons to quantify the gains of just the cam. The gains will also vary depending on your fuel, turbo, timing etc.,
  #143
Old 12-07-2015, 12:05 AM
88 Ford IDI 88 Ford IDI is offline
88 Ford IDI is starting off with a positive reputation.
Quote:
There are dyno numbers of trucks with the cam but no before and after numbers. You could always be the first...
  #144
Old 12-07-2015, 12:35 PM
The_Josh_Bear The_Josh_Bear is offline
The_Josh_Bear is starting off with a positive reputation.
Quote:
Isn't it a royal PITA to put a cam in a V-8?
Something like this:
Pull everything in front of the engine, pull crank/water pulleys, pull timing cover.
Pull valve covers and lift entire valve-train(does that mean head bolts??), and find a way to hold the pushrods up and away from the cam.
Then pull cam, reinstall new cam with assembly lube. (Whole can of worms with pulling cam gear and installing on new cam too)
Reinstall everything in reverse order.
Let me know what I missed guys, thanks.
Joshua
  #145
Old 12-07-2015, 12:46 PM
79jasper 79jasper is offline
79jasper is gaining momentum as a positive member of FTE.
Not quite that complicated.
Don't know why you would ever need to pull the heads.
If you pull the valley pan you can easily get at the push rods and lifters.
  #146
Old 12-07-2015, 01:28 PM
Ford F834's Avatar
Joshua
Yes, it is major surgery. You do not have to disturb the head fasteners though. The IP and injector lines need to come off so you can remove the intake, valley pan, lifter retainer and lifters. Then everything on the front of the engine.The front clip has to come off or else the radiator, AC condenser and grille can be removed. I've pulled a couple of cams at the junkyard to get cores. It's not too horrible but a full swap with putting everything back would be an all day event, possibly more if you ran into any complications.
  #147
Old 12-07-2015, 02:40 PM
typefour's Avatar
typefour typefour is offline
typefour is starting off with a positive reputation.
When the cam was first developed it made 11% more torque and HP across the board.
That was 20 years ago. So, just a hp number isnt really important as the timing fuel and all the other variables can affect those results in IDENTICAL trucks.
The gain is important. I might do a before and after on the dually just cause.
  #148
Old 03-13-2016, 10:09 AM
Trev1lov3 Trev1lov3 is offline
Trev1lov3 is starting off with a positive reputation.
This has been a sick thread to follow got a 90 n/a idi and cant wait to start doin some work now.
  #149
Old 10-14-2016, 03:16 PM
3for1's Avatar
3for1 3for1 is offline
3for1 is starting off with a positive reputation.
IDI Cam
I was wondering if these cams are still available and how much they cost?
I know it is an older thread so am curious if they are still available
  #150
Old 10-14-2016, 03:53 PM
Email Russ(Typ4) with your question at:
Sandeater1@gmail.com
He's still around and doing good business. I just had my IP rebuilt with him a month or so ago.
1996 5.8l roller engine questions Pat54632 Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W) 40 02-23-2017 09:49 AM
93 7.3 IDI build IDIoit Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 170 02-08-2017 10:17 PM
?DB2 Automatic Advance ADJUSTMENT? and I/P Timing HELP Needed in Germany Fixnstuff Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 51 06-17-2016 10:26 PM
DiMora's 400 build - part deux dimora 335 Series- 5.8/351M, 6.6/400, 351 Cleveland 175 04-04-2015 04:48 AM
'94 351w stock head/cam spec's? minnesota4x4 Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W) 2 04-06-2003 11:27 AM
Tags
1999, 73, bigger, cam, camshaft, engine, f250, idi, international, logger, logging, profiles, stock, theory, turbocharged, type, type4, upgrade
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
