adjusting clutch - Need help asap - Ford Truck Enthusiasts Forums
Old 02-14-2010, 01:20 PM
chappys4life's Avatar
chappys4life chappys4life is offline
chappys4life is starting off with a positive reputation.
I went out to adjust my clutch today cause it felt like it needed it. Seemed like the clutch was releasing very close to top. I looked in the factory shop manual for the proper technique just to double check.
So get the truck jacked up and loosen lock nut and bring adjustment nut out some tighten lock nut. Lower truck put in neutral and start truck but now I cant get it into gear. Trying to figure out whats wrong here as there was lots of rod left to to bring the nut out more. I am tempted to try bringing the adjustment nut out more but kind of nervous.
Any ideas or what am I doing wrong? Also when I bought the truck about a year ago he claimed it had a newer clutch and it would seem that way since the adjustment nut was pretty close to the threads closet to the rear of the truck.
Old 02-14-2010, 02:14 PM
ALBUQ F-1's Avatar
ALBUQ F-1 ALBUQ F-1 is online now
postin' fool
ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.
What year truck is this?
It sounds like you made it looser, not tighter. While you're under there, grab the clutch pedal from underneath, and watch how the linkage moves as you "pull" it down. You have to pull the pin out of the clevis, then turn the clevis on the rod, to make a difference; it isn't a turnbuckle (at least on 48-52's).
Old 02-14-2010, 02:16 PM
It is a 53 f100 with the standard 3 speed light duty shifted on the column with the v8 flathead. It says in the manual it its just a adjustment nut and lock nut on a threaded rod for the clutch pedal adjustment.
Old 02-14-2010, 02:44 PM
Okay I think I have it now. I was curious though on the transmission for the plug that us used to drain the fluid and add fluid. What type of tool do I need to remove it? It looks like a square.
Old 02-14-2010, 03:16 PM
gdgerland gdgerland is offline
gdgerland is gaining momentum as a positive member of FTE.
If I remember correctly, a half inch ratchet and extension will do the trick.
Gil
Old 02-25-2010, 06:34 PM
57Blueboat's Avatar
57Blueboat 57Blueboat is offline
57Blueboat is starting off with a positive reputation.
Hey have a 57 F100 with 3 speed light duty. The clutch slips and angrily engages sometimes, especially at low RPM with too much throttle ( more than 1/4 or so ). Anyone with experience think this is probably a simple adjustment, and if so what would be your guess. I was told by a friend that owns a '55 and '56 that it probably just need the hydraulic fluid level checked or some other minor adjustment.
Old 02-25-2010, 07:51 PM
Julies Cool F1 Julies Cool F1 is offline
Julies Cool F1 has a great reputation on FTE.Julies Cool F1 has a great reputation on FTE.Julies Cool F1 has a great reputation on FTE.Julies Cool F1 has a great reputation on FTE.Julies Cool F1 has a great reputation on FTE.
Well, it's not hydraulic fluid, I think we can all be sure of that!
It sounds like you either have clutch chatter from poor alignment, or you have a pressure plate spring or two that are broken.
Not a simple adjustment in either case.........
Sounds like it's time for a new one. I might be tempted to take it to a clutch shop to have it replaced.
Old 02-25-2010, 08:02 PM
rbig1 rbig1 is offline
rbig1 is starting off with a positive reputation.
do you have free play at the to of pedal around 1/2 inch at least. may have never been adjusted. lining gets hot and bites
Old 02-26-2010, 11:18 AM
57Blueboat's Avatar
The pedal has at least a half inch of free play at the top. Sorry Julie meant clutch fluid for the system. Figured it needed a new clutch but was just hoping I could get by with some minor adjustments for now to keep it going. Just another thing to add to the list for the truck.
Old 02-26-2010, 11:43 AM
AXracer's Avatar
AXracer AXracer is offline
AXracer has much to be proud ofAXracer has much to be proud ofAXracer has much to be proud ofAXracer has much to be proud ofAXracer has much to be proud ofAXracer has much to be proud ofAXracer has much to be proud ofAXracer has much to be proud of
Most clutches in our era were mechanical linkage, not hydraulic. Unless you have two master cylinders, one on each pedal, there is no fluid in the clutch mechanism.
If you have ~ 1/2" of free play at the top (push on the pedal by hand and see how far it depresses before it begins to get stiff, that's the free play) if you have much more than 1/2" it is adjusted too loose. Sounds to me like a worn out clutch disk or a worn/hardened engine rear main bearing seal leaking oil onto the clutch. Baby that clutch until you can determine the problem and fix it, or you may find yourself having to make an unexpected long walk late at night. Not the way to impress a SO!
Old 02-26-2010, 04:38 PM
ALBUQ F-1's Avatar
postin' fool
I thought '57 - on were hydraulic clutches?? We get a lot of complaints about burst or leaking hoses etc. I "think" I see a clutch master on the firewall in the pictures in his gallery (note to Blue -- cell phone pics won't cut it around here! )
Old 02-26-2010, 05:40 PM
57Blueboat's Avatar
Yah '57 was the first year for hydraulic clutches. The clutch works fine for me I just drive nice and easy and its okay but in the long run it would be nice to be able to give it a little throttle so it can get out of its own way. I don't own a digital camera so cell phone it will be, thats enough technology for me.
Old 02-26-2010, 07:10 PM
well what do ya know learned something today and it didn,t hurt. didnt think hyd clutches started that early. never mind the free play comment. dont know if there is a bleed screw for air in system and dont know directions for bleeding
ALBUQ F-1's Avatar
postin' fool
It could be you just need to add fluid or bleed the system, but after all these years the rubber seals could be shot. Rebuild kits (rubber parts) are cheap, check NAPA:
Clutch Master Cylinder kit| NAPA Online
Clutch Slave Cylinder| NAPA Online
But it sounds like you're saying it's slipping? That's more likely the clutch itself.
Old 02-27-2010, 03:01 AM
AXracer's Avatar
Does it have an internal hydraulic throwout bearing or a mechanical type TB with a slave cylinder to activate it? Unless you have no free play at all the hydraulics won't make a "juice" clutch slip. Still sounds like a worn or oily clutch disk.
Adjusting free play in clutch Eddillard79 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 4 04-15-2014 03:42 AM
How to adjust my clutch DanielT28 1994.5 - 1997 7.3L Power Stroke Diesel 1 09-18-2012 07:50 AM
Clutch Springs, Z bars, and Other stuff Broomfieldbum 1961 - 1966 F-100 & Larger F-Series Trucks 17 09-05-2012 02:47 PM
Steering box adjustment, have we been doing it wrong? Snowseeker Excursion - King of SUVs 19 06-20-2012 10:32 PM
Fan CLutch Removal dakotajeep Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 7 05-21-2009 12:02 AM
Tags
150, 1955, 1997, 2009, 200sx, 2110, adjust, adjusting, adjustment, bonneville, clutch, complaints, f100, fluid, ford, nissan, triumph, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
