Vibration problems... common?
Hey guys,
I have an 07 F-150 and about two months ago I put some new tires on it. I went with the GoodYear Wrangler DuraTrac and they are slightly larger in diameter than the stock tires. The truck always seemed to ride completely smooth prior to the new tires, and now I have a vibration which comes on at about 54 MPH, and seems to completley go away by about 60MPH. The vibration is also sometimes more severe and sometimes less severe and is never predictable. There is nothing I have been able to do to make it come or go. I took the truck back to the tire dealer several times with a complaint of vibration and each time they woudl re-balance the tires. The first time I left when the tires were brand new the vibration was the worst after about 20 miles of driving. When I took it back they said it looked like I threw a weight on each wheel. Both times after that they told me that the wheels balanced perfectly without any changes. I had originally thought that what might have happened was when they changed the tire they knocked one or more of my tire pressure sensors loose and they were flopping around inside the tire when I drove. I had a theory that sometimes the pressure sensor would be in a "good" location where the tire was still balanced and it would be smooth, but other times it would be in a "bad" spot and it would be out of balance and vibrate. I recently talked to a reputable Ford mechanic who told me that he's seen this type of problem all the time on the 2004-08 ford trucks and that every one of them has some degree of vibration at some speed. He showed me a Ford TSB which highlights the problem and recommends purchasing a fix and installing it on the rear left side of the frame. The fix looks to be a cast iron block with rubber mounts. Now I'm starting to think that with the stiffer and larger tires on my truck, I have made the vibration more significant and have moved the vibration to a speed where I notice it more. Has anyone had this happen to them or heard of this?
Jesse
Jesse
My 04 STX regcab 4X4 rides smooth at all speeds. I can't say that I ever notices a vibration at any speed. Have you looked into the possibility of one or more of the tires being out of round. I had that happen to me on a different vehicle. It is very frustrating try to find the cause of the vibration when it is one of the tires.
Good luck.
Good luck.
Hey guys,
Jesse
Jesse
very very common issue man. especially the 04/05 trucks.
several easy fixes
1. Get each wheel "ROAD FORCE BALANCED"
2. While the rims are off, check each lug stud for a tiny little retainer washer...remove
3. When installing rims back, ensure they are only torqued on at 150 ft-lbs...tighter can cause vibration
after that, then I would start looking at bent/worn out stuff
several easy fixes
One thing to remember is that all balancing machines are not created equal. Nor are the people who work them. I had a vibration that I thought was the tires so I took it to the local tire shop where I bought them. After two trips there with the problem persisting I took it to a Ford Dealership where they discovered they were fairly imbalanced. Apparently they had a monkey working the tire machine at the local shop. Long story short mabye try someone else.
annaleigh
12-04-2015 07:54 PM
wogdiml
1999 to 2016 Super Duty
29
11-19-2010 03:52 PM
expo54bx
1997-2006 Expedition & Navigator
10-02-2010 12:52 PM
