Carb mounting questions
Old 09-19-2012, 10:44 AM
84espy's Avatar
84espy
84espy is offline
I have been looking at carbs for the 75 and am a little bit stumped. I have the spread bore manifold. The new carbs come with a square bore. The adapter plate mounts the square bore carb to my spread bore manifold, correct? If so, what does this do to the flow inside the manifold? Were there any stock square bore manifolds made? Engine is a 460.
Old 09-19-2012, 04:13 PM
kenny nunez's Avatar
kenny nunez
kenny nunez is offline
spread bore
84espy, If you have a Motorcraft carburetor spread bore there is an adapter that will fit and work properly. I did this very thing a few years ago with no problems. Which ever carburetor you choose just make sure it has features for Ford use. Kenny
mOROTBREATH
07-12-2009 11:41 PM
460_Sprout
06-10-2005 06:46 PM
F250duke
06-15-2004 08:35 PM
dbarracuda
02-08-2004 03:11 PM
aunchman
09-24-2003 08:00 PM
Quick Reply: Carb mounting questions
