1961-1964 262 6 cylinder questions - Ford Truck Enthusiasts Forums
Old 02-13-2010, 04:47 PM
Knoxville Knoxville is offline
Knoxville is starting off with a positive reputation.
I just bought a '60 ford f100 with a '61-64 commercial 262 swapped into it. It's supposedly in the same family as the 215 and 223 motors.
I think it needs a valve adjustment,
Does anyone have valve lash specs for this motor??
Or any other sources of info?? I'm havin a hard time finding info on it, thanks for any help.
Knoxville
Old 02-13-2010, 05:10 PM
flipklos flipklos is offline
flipklos is gaining momentum as a positive member of FTE.
.019 should be about right.
Old 02-14-2010, 09:00 PM
Thanks.
Know of any good sources of info for these motors? I have a feeling i'm gonna need it later on.
Old 02-14-2010, 10:32 PM
Timing is at about 6-10 degrees.
Lash .019.
Plug gap .035.
Point gap .025
I got these by just googling ford 223 tuneup. A factory service manual from 1958-64 truck would give you a solid ballpark figure.
Old 02-15-2010, 07:44 AM
chrlsful's Avatar
chrlsful chrlsful is offline
chrlsful has a good reputation on FTE.chrlsful has a good reputation on FTE.chrlsful has a good reputation on FTE.
No forum here for that?
Old 02-15-2010, 10:01 AM
oldbrokecowboy oldbrokecowboy is offline
oldbrokecowboy is starting off with a positive reputation.
262
You're in it. You can also try the appropriate years pickup forums here. If you can't find help/directions to/ or what ever here it does'nt exist. Great site/ people. Only my opinion.OBCB
Old 02-15-2010, 10:18 AM
chrlsful's Avatar
Yes, there is:
61 - 66 F-100 & Larger F-Series Trucks
Knoxville - mights well go to the source, did U C the above, one of our forums? Go to the very top of this page and click on Forums (is in grey colored area).
Old 05-29-2010, 09:08 PM
wills 64 wills 64 is offline
wills 64 is starting off with a positive reputation.
i have 64 with 223, want to cam it up, bore 30t. over ,put 4brl manfoild on with a split . what do you think. will
Old 05-29-2010, 09:50 PM
chrlsful's Avatar
223
Quote:
I believe his name is Cornel Flashman (help me out guys) works on these, is a member. May B go to the member's list page(s) to PM him.
64 F100 262 hydraulic or solid lifters? scottiethebarber 1961 - 1966 F-100 & Larger F-Series Trucks 2 10-06-2015 02:36 PM
XE262H Cam ignition timing question Riderman FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428) 34 01-11-2010 11:01 AM
replacing lifters on a 262 I6 tips? justinfown1 Ford Inline Six, 200, 250, 4.9L / 300 2 08-18-2008 06:20 PM
who here knows about knoxville? may be moving bf250 Tennessee Chapter 10 07-08-2007 03:13 PM
Knoxville? thunder struck Tennessee Chapter 69 01-07-2006 09:04 AM
Tags
1964, 223, 262, 300, 64, 6cylinder, cylinder, engine, engines, f100, ford, gap, plug, point, setting, settings
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
