1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Amp research steps
Old 02-13-2010, 02:48 PM
TP83's Avatar
TP83
TP83 is offline
Amp research steps
I really like the look of these steps and had a couple questions for those that have them. Currently i have my compressor and air tank under the passenger side, outside of the frame rail under the truck so i am not sure if it will fit. how much clearance is between the brackets/step and the underside of the cab aswell as the frame? and does anyone have some pictures with the steps up under the truck so i can see if i can make it work? Thanks.
Old 02-13-2010, 07:19 PM
_Rick_'s Avatar
_Rick_
_Rick_ is offline
Taylor,
Not very clear diagrams of what you need to know, but you might find it helpfull (AMP Research Steps Install Instructionshttp://www.amp-research.com/pdflibra...M2513_F250.pdf)
To be safe I would recommend sending AMP Research an E-Mail with a photo of your compressor location and get their feed back.
info@amp-research.com
Rick...
Gwilkrrs
04-03-2015 07:35 PM
AFordMan
1997 - 2003 F150
09-12-2013 01:58 PM
DieselBeast01
2004 - 2008 F150
23
08-29-2012 11:11 PM
buckshot1822
18
07-06-2011 04:18 PM
wongs83
04-11-2011 06:14 PM
Quick Reply: Amp research steps
