Need 12 volt hot power source...
Old 02-13-2010, 11:42 AM
afonda's Avatar
afonda
afonda is offline
looking for a 12 volt unswitched power source.
I am going to hook up a CB Radio and I want to be able to turn it on with out the key in the ignition.
Obviously I could run a lead right to the battery but I am looking for a clean power source.
Old 02-13-2010, 11:45 AM
parkland's Avatar
parkland
parkland is offline
I just snuck a wire in the radio fuse when I had a CB
Old 02-13-2010, 01:49 PM
guitarpicr's Avatar
guitarpicr
guitarpicr is offline
You could probly use the lighter wire. Should be hot all the time
Old 02-13-2010, 02:04 PM
ampslw's Avatar
ampslw
ampslw is offline
you could use
there is a hot wire that feeds the fuse box good power souce hot all the time but becareful not to ground the 10 or 11mm socket on metel in the dash when removing the nut
i would also put a in line fuse on that wire close to the sorce of power ( + )
Old 02-13-2010, 03:20 PM
afonda's Avatar
afonda
afonda is offline
Can you be a little more specific on where this wire is ?
Thanks.
Old 02-13-2010, 03:41 PM
farmdad's Avatar
farmdad
farmdad is offline
Wouldn't a wire directly to the battery be cleaner than any other source? Then you wouldn't have any static being developed by the alternator, heater fan motor, turn signals or any other electric component.
Old 02-13-2010, 03:47 PM
ampslw's Avatar
ampslw
ampslw is offline
Thanks.
this is the fuse box for 2002 f550 my spair
there is a plastic cover over the nut that comes off it has too little clips on the sides
this wire is power feed for the fuse box comes rate from the batties.
"i know i cant spell good so i work with my hands "
Old 02-13-2010, 03:56 PM
ampslw's Avatar
ampslw
ampslw is offline
well ....
but putting a nother hole in fire wall and running a wire from bat to the cab can be even messer look like crap if not in loom and put away nice.
trust me look at my truck when i first got it, it still bother me when i look at it to long
Old 02-13-2010, 04:59 PM
farmdad's Avatar
farmdad
farmdad is offline
I guess I misunderstood your post. I thought you meant "clean power" not clean looking. I see what you are getting at.
Old 02-13-2010, 05:39 PM
Ponyboychris's Avatar
Ponyboychris
Ponyboychris is offline
Hit it!
There should be a bundle of four wires by the PCM and the e-brake marked "customer access." These wires pass through the fire wall to the engine bay for these kinds of additions.
Old 02-13-2010, 05:46 PM
big poppa's Avatar
big poppa
big poppa is offline
Chris is right, right next or behind the OBD port, you'll see a wire harness, a plug in of sorts, tap into the hot from there, I want to say red with blue trace but not certain. I ran mine right to the battery, its clean.
Old 02-13-2010, 08:51 PM
afonda's Avatar
afonda
afonda is offline
Just to clarify....
when I said clean power source.... I meant clean power with no engine noise.
Thanks.
Old 02-13-2010, 09:11 PM
big poppa's Avatar
big poppa
Gotya, right to the battery I did with no interferance. No engine noise..
xaviar
09-22-2021 02:01 PM
White gold
2017+ Super Duty
02-23-2017 12:36 AM
stufarmer
1999 to 2016 Super Duty
24
01-08-2017 04:21 PM
RV_Tech
11-15-2016 07:24 PM
mr. dave
General Automotive Discussion
03-22-2009 08:34 PM
Quick Reply: Need 12 volt hot power source...
