Massive Coolant Leak 4.6 litre - Ford Truck Enthusiasts Forums
Old 02-13-2010, 11:25 AM
merten's Avatar
merten merten is offline
merten is starting off with a positive reputation.
I posted this on the engine forum. This is not a truck, it is my Thunderbird.
Hi all I have 1996 <nobr style="font-weight: normal; font-size: 100%; color: darkgreen;" id="itxt_nobr_0_0">Ford</nobr> with the 4.6 litre engine. On the way home from work while driving at freeway speed I got a low coolant warning. I quickly pulled off of the highway and shut engine off. There was coolant pouring out from the back bottom of the engine. I towed it home and have put it up on ramps to get a closer look. I can see water coming from the area between the transmission and the back of the engine . It does not appear to be coming from the top of the engine. Any ideas?
Old 02-13-2010, 11:55 AM
mr4speedford's Avatar
mr4speedford mr4speedford is offline
mr4speedford is starting off with a positive reputation.
On the early 4.6s there is a coolant tube that runs from the back of the water pump to under the intake. I don't know if your car has one. Those 4.6s are know for the intake cracking, but thats on the cross-over upfront and I would assume you could see it. Check the heater hose connections too. Good luck.
Old 02-13-2010, 01:20 PM
eman92082's Avatar
eman92082 eman92082 is offline
Monkey-Face in Your Face!
eman92082 has a great reputation on FTE.eman92082 has a great reputation on FTE.eman92082 has a great reputation on FTE.eman92082 has a great reputation on FTE.
Have you had you collant changed recently ? The intake manifold is plastic. At the rear of the manifold there is a hose that needs to be removed from the fitting to burp air out of the system. This fitting is not threaded. It is either molded or press-fit in. When removing the hose, this fitting will either loosen or come out.
I had this problem on my Mustang GT and ended up cleaning carefully, then epoxy the fitting in. It would probably be better to pipe-tap and thread a fitting in.
I went to Ford about this and of course, their solution was a new manifold....
E-Dawie
Old 02-13-2010, 04:39 PM
merten's Avatar
Thank you for the feedback. There is no coolant leak up high on the motor. It is nice and dry. I started it up and the water pours out between the end of the oil pan flange and the trans. bell housing. When it is idling there is a lot of steam out of the tailpipes. Water is dripping out of the mufflers.
Old 02-13-2010, 04:48 PM
rb48f6's Avatar
rb48f6 rb48f6 is offline
rb48f6 is gaining momentum as a positive member of FTE.
Check your dipstick for water content in the oil. And/or if there's any coolant left in the radiator or overflow is it oily. With steam coming out the exhaust, and I'm guessing it's not normal, I'm going to guess head gasket. Around here this time of year we get the condensation out the tailpipes on a reg basis.
Old 02-13-2010, 06:23 PM
merten's Avatar
No coolant in the oil, and could not see any oil in the coolant that was coming out of the bottom. I was thinking head gasket also because of the water out the tailpipes, but wondered why it would be leaking at the back of the engine.
Old 02-13-2010, 06:36 PM
55 f350's Avatar
55 f350 55 f350 is offline
55 f350 is a splendid one to behold55 f350 is a splendid one to behold55 f350 is a splendid one to behold55 f350 is a splendid one to behold55 f350 is a splendid one to behold55 f350 is a splendid one to behold
the early 4.6's are to what i've read prone to popping head gaskets . mine hasn't yet , but i'm waiting for it . you ckecked the coolant lines ? and there is a coolant tube under the intake , and those dain plastic intakes have that beloved fitting eman is talking about too . so you got a whole long list of things to look at . according to those who are in the know my aluminum intake is a pos for performance use , but i dont have any of the issues the rest suffer !!!!!!!!!!!!!!!!!!!
Old 02-13-2010, 06:42 PM
councilman's Avatar
councilman councilman is offline
councilman is starting off with a positive reputation.
I agree with mr4spd coolant pipe under intake or cracked intake manifold.
Old 02-13-2010, 06:45 PM
merten's Avatar
The coolant lines to the heater are not leaking. This car was owned by my Dad since new. I think that he had the intake replaced by Ford under warranty. Would a bad head gasket cause an external leak?
Old 02-13-2010, 07:26 PM
52 F3's Avatar
52 F3 52 F3 is offline
52 F3 is starting off with a positive reputation.
I agree wit the others.
I've seen it many times.
The intake cracks and leaks into the valley beneath the intake and runs out the back in the flywheel housing.
Old 02-14-2010, 09:11 AM
merten's Avatar
Thanks all for fielding this question. It is the intake manifold. It ruptured on the bottom and leaked into that valley. When it blew at highway speed it sent coolant all over the place. Now it just runs to the back and drains down between the block and the trans., giving the illusion that it is leaking out of the back of the engine. When I pulled the alternator, I could get a hand up under the manifold and can feel a crack that is about 4" long.
I see were they are selling these manifolds with the coolant passage made out of aluminum and the rest of the manifold out of plastic. Does anybody who has replaced this have a preference as to were to get a replacement?
Old 02-14-2010, 09:18 AM
I've always had good luck with dorman brand replacement intakes. They usually re-engineer the part so that it won't repeat. They should carry it at a local autoparts store.
Engine Swap: 6.9L IDI into a 1976 Highboy 76-high-boy Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 26 12-02-2011 06:38 PM
96 powerstroke fuel lines Wiggin 1994.5 - 1997 7.3L Power Stroke Diesel 8 07-31-2010 06:11 AM
short or ground issue? turn signals and parking lights puck1263 Electrical Systems/Wiring 9 05-20-2010 04:50 PM
Hard fault... Whats it mean? BRay09 Ranger & B-Series 2 01-08-2010 06:54 PM
look at this, NO MORE 6.0 DIESEL??? kips 1968-2013 Full Size Vans 3 02-28-2008 04:23 PM
Tags
46, 97, coolant, coolent, cracked, f150, ford, intake, leak, manifold, rear, repair, thunderbird, water, ways
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
