351w 235 omc - Ford Truck Enthusiasts Forums
351w 235 omc
Old 02-13-2010, 01:20 AM
unclejunk's Avatar
unclejunk unclejunk is offline
unclejunk is starting off with a positive reputation.
351w 235 omc
any body here no any thing about the 351w 235 omc boat engine from the early to mid 70s
Old 02-13-2010, 01:46 AM
unclejunk's Avatar
what r the difs between this 351w omc boat engine and a automotive 351w
Old 02-13-2010, 02:03 AM
f250meatwagon's Avatar
f250meatwagon f250meatwagon is offline
f250meatwagon is starting off with a positive reputation.
im not sure but i thought i saw some where that some marine engines have a different rotation than street engines
Old 02-13-2010, 09:04 AM
unclejunk's Avatar
i pulld in a 87 f250 yesterday and the guy i got it from and the tags on the valve cover says its a 351w 235 omc made in 1970 ?
Old 02-13-2010, 09:16 AM
NumberDummy's Avatar
NumberDummy NumberDummy is offline
Ford Parts Specialist
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
FTE member Arctic Y Block has a 351W marine engine in his boat.
I don't recall the manufacturer of his boat, but it's of mid 1970's vintage.
Old 02-13-2010, 10:58 AM
Conanski's Avatar
Conanski Conanski is offline
Conanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud of
The short block is the same as an automotive engine, but the marine version would have a different cam(and possibly a reverse rotation verion), and it would have had a cast iron intake and marine exhaust manifolds originally but these parts would have been changed to put it in a truck.
Old 02-13-2010, 05:46 PM
unclejunk's Avatar
explains the high rev it tacs out on the gage a three ouaters of the way into the gas pedal at 6000 rpm s and its not even at full throttle what about the heads im going to pull it out tommorow and see what it has for heads
Old 02-13-2010, 06:35 PM
Conanski's Avatar
Look for a capital letter cast into the outside/top corner of the head near the valve cover or between the first and second bolt. GT will be GT40 heads, R will be E5TE and T will be E7TE heads. If none of these exist you'll have to pull the intake and get the casting number from the underside between the inner intake ports.
Old 02-13-2010, 11:54 PM
unclejunk's Avatar
i took of the valve covers wcp 351 or 4f13 are the only numbers i see and also the tops of the push rods are threaded the nut to hold down the rocker arms threads onto the push rod
Old 02-14-2010, 12:07 AM
Conanski's Avatar
No I meant outside the valve cover as seen in this pic. GT40Heads1 on Flickr - Photo Sharing!
If there is nothing there the casting number is on the head gasket side, so you have to remove the intake and and look under the intake ports with a mirror. Some examples can be seen in this pic.. http://farm4.static.flickr.com/3045/...e5db1341_b.jpg
Old 02-14-2010, 12:15 AM
unclejunk's Avatar
going to get the mirror rite now i will check under
Old 02-14-2010, 12:33 AM
unclejunk's Avatar
ok here we go to the best of my vision the number is DooE c on the head and the block cast numbers are E4AE-6015-FA -5 7A29 any of this make sense
Old 02-14-2010, 07:57 AM
ljeeper ljeeper is offline
ljeeper is starting off with a positive reputation.
I have exactly the same engine in my Jeep. It is a 1974 marine engine that i got free from a mechanic friend that has a boat shop.
I had the low end rebuilt with off the counter parts from any autoparts
stores. I used a 1978 flywheel and clutch parts bolted to an NP435/205.
I then added an Edelbrock performer top end kit, 670 truck avenger, shorty headers and HEI distributor. Happy with the results i estimate 350 HP and 400 lbs.
All parts are interchangable with any 351w.
GH
Old 02-14-2010, 10:41 AM
BaronVonAutomatc's Avatar
BaronVonAutomatc BaronVonAutomatc is offline
BaronVonAutomatc is gaining momentum as a positive member of FTE.
D0OE heads are the old model 351 castings, not bad if you're only planning on a valve job and cam with less than ~.45" lift. Auto engines use rail rockers, never seen one with bolt-down pushrods though. I've got to figure that's an even worse set-up for any kind of performance engine...
Old 02-14-2010, 10:56 AM
Conanski's Avatar
Quote:
That's '70 351 heads on an '84 shortblock.. a good combo.
OMC 235 302 or 351? tazman85305 Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W) 2 10-03-2015 12:32 AM
1977 351 OMC Marine build jstitts Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W) 20 05-14-2013 10:56 PM
Torque converter stall speed & towing jmtmt 1987 - 1996 F150 & Larger F-Series Trucks 5 02-06-2012 10:43 PM
best chip/programmer for the 6.0 omc124 6.0L Power Stroke Diesel 7 05-10-2011 09:57 PM
Marine 351W Backfiring Through Carb KRH1326 Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W) 1 04-23-2009 07:41 PM
Tags
235, 351, 351w, block, boat, d00e, engine, exhaust, ford, gt40, heads, intake, marine, omc, truck, wcp14
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
