Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > 2007+ Expedition & Navigator
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
2007+ Expedition & Navigator 2007, 2008, 2009 and 2010 Ford Expedition and Lincoln Navigator
  #1 (permalink)
Old 02-12-2010, 10:40 PM
clum553946 clum553946 is offline
Garage is empty, add now
clum553946 is starting off with a positive reputation.
08 Expedition Aftermarket Limited Slip
Is there an aftermarket limited slip diff. for the rear of a 4x4 08 Expedition E. Bauer? Will this cause any problems if you install one?
Thank you.
  #2 (permalink)
Old 02-15-2010, 06:16 PM
gpfarrell gpfarrell is offline
gpfarrell is starting off with a positive reputation.
I think you can buy anything.
But I'd think it would mess up the traction control which isn't programmed to recognize it.
I think some limo versions (?) may have had factory limited slip?
  #3 (permalink)
Old 02-15-2010, 06:42 PM
GlassLeather&Wood GlassLeather&Wood is offline
GlassLeather&Wood is starting off with a positive reputation.
I would not worry with a limited-slip rear differential (this being my honest opinion)
4-wheel electronic traction control comes standard (bundled with the AdvanceTrac electronic mitigation suite) on all 4-wheel-drive equipped Expeditions. It gives the same performance as a limited-slip rear differential with none of the shortcomings. Also with it being a true 4-wheel system, it also gives the performance of a limited-slip front differential.
How 4-wheel electronic traction control is better than a LSD ...
1: It reduces drivetrain stress.
2: Driver control is not affected.
3: Less complexity means improved durability.
4: It can react faster than a mechanical limited-slip differential.
5: It will never lose its effectiveness over the life of the vehicle.
Some limited-slip differentials will lose their ability to transfer torque
as the internal slip inhibiting device (usually a clutch system) becomes
worn from use. Eventually they will revert back to a open differential, and
must be repaired.
If you want to improve traction, then a electronic locking rear differential would be a better choice. It would also complement the electronic locking center differential that comes standard with ControlTrac 4-wheel-drive.
With both rear wheels locked together, AdvanceTrac would not engage as there wouldn’t be any slipping between them. AdvanceTrac would continue to look after the front wheels and step in if either one lost traction.
Ford already has this setup in the 2009 Ford F-150 FX4. AdvanceTrac looks after all four wheels and steps in if any of them lose traction. If more traction assist is needed, the rear differential can be locked. Then AdvanceTrac just takes care of the front wheels, since the rear locker takes care of the rear wheels.
Tags
2000, 2007, advance, aftermarket, differentia, differential, differentials, expedition, ford, limited, locking, slip, trac, truck, trucks
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
