You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
2005 E-450 with a V10 and what I think is a 4R100. It has 31'XXX miles, and my father is asking what should be done. This is a Class B+ van front motorhome. Flush? Drain'filter, fill?
Its probably the 5R100 if I had to guess. You could certainly do a drain/filter job. A flush would probably be overkill for only 31k miles. The filter is probably 10-12 dollars along with a gallon or two of ATF and you should be all set.
__________________
Greg (aka Montana Heavenjugs)
2001 F250 XLT PSD CC SB - Tuned by Gearhead
6637 w/ Pete's cover; DashDaq; RR HPX, FRx; 5" MBRP SS turbo back; 6.0 IC and trans cooler; Retrax bed cover NorthEastSevenThrees <-- link to our homepage
__________________
One is a suction screen which is R&R'd by dropping the transmission pan.
The other is a bypass filter 'toiletpaper' in a bowl alongside the transmission.
Note that that bowl can be a tough nut to unscrew.
__________________
Dave ~*~ Mods are listed in my Gallery (Updated 03/11/2010) Former Connecticut Chapter Leader Feb. 06, 2009 to Aug. 22, 2010.
2006 E35Q 6.0 5R110 35.4" Tires & 5.13 Diff., Unicell's Aerocell SRW body with Quigley 4x4 Conversion - - - 2004 Expedition XLT 5.4L 4X4 4R75W 3.73 Posi
Prior: Courier Pickup and a 1991 Crown Victoria Interceptor
The answer is torque capability, and apply the same to your 115.
I forget where I came upon this:
As for the 110, that represents 1100 lb-ft, but that's AFTER the torque converter multiplies engine torque by 1.9:1. That means it can take about 580 lb-ft of engine torque.
__________________
