Brake Controller Help
My brake controller recently stopped working. I'm hoping someone can provide me some more information on how to test controllers.
Truck: 2001 F250 PSD
Controller: Tekonsha Voyager
The trailer lights, etc, all work fine. However, the green light on the controller doesn't illuminate when the trailer is connected. I'm also unable to engage the trailer brakes by pulling the manual lever.
I tested between the ground and brake controller tabs on the truck side of the harness. I found 12.7 volts constant and about 12.4 when the brakes are applied.
What additional tests and troubleshooting should I complete to verify if the controller is broken?
Thanks!
Thanks!
Thanks!
Thanks!
Follow your seven pin cord back on your camper and check for broken connections or possibly a blown fuse. You most like have a broken lead to your trailer brakes or a shorted lead that is blowing a fuse or keeping an auto reset fuse from resetting. Once you have power to your seven pin, that is as much as your brake controller can do, if I am understanding your situation correctly.
Steve
KHAYES
Other; Brakes, Electrical, Hitches, Weight Distribution & CDL Discussion
06-12-2013 12:09 PM
dixie217
05-12-2009 08:44 PM
trike1946
20
01-05-2005 09:13 PM
